What have you done to your car today?
22 Sep 2011
Staffordshire Somewhere
MOT on Monday so fixed the slide mechanism on my corollas' drivers seat. Retarded design in regards to the size of the 'pins'. Drilled out where the pin snapped off, tapped it and red loctite in some 6mm high tensile bar, much stronger. Need to do the passenger side next when I can be bothered.
21 Jan 2010
Ceredigion
That for the E12s? Is there a proper guide out there? Slide mechanism on my partners Corolla is stuck. Oddly I never had the issue in my Corolla so no idea how to do it.
22 Sep 2011
Can show you step by step buddy, be warned you will need a HSS drill set; a 4mm @ 6mm @ X 1.0 tap, a 5.2/5.5mm drill for the tap. Get some 6mm x 1.0 threaded bar (make sure it's high tensile). Some red loccitite and a centre punch. + the essential hammer.
Set out work area
Disconnect battery (wait 5 mins)
Take the seat out of the car (4 bolts) 2 rear plastic covers.
Flip seat and put rails at max height, take off plastic on the side of the seat (you will need TORX):
Go 4mm to 5mm to 5.5mm drill:
Run 6mm x 1 tap through drill holes:
RED loctite the end of threaded bar and put it all the way through the drilled / tapped hole until you meet resistance.
Cut off & grind off until it sits flush. (nut is optional but it helps to take out any flex)
Caporegime
29 Jul 2011
In acme's chair.
From memory we took the seat out, drilled out a stuck pin, ground down a bolt to a tapered point, and screwed it in in place of the pin.
I'm sure there are more detailed guides though, as per above!
21 Jan 2010
Ceredigion
Thank you very much, that's superb!
Thanks!
3 Jun 2012
How much of a shed is this heap that you constantly have issues to fix, are always chasing faults, and now you have to have a special MOT to keep it on the road.
What are you on about?
Constantly having issues to fix? I've had very few. Also I've not done anything but service it for months.
It's a very fine example of an MPS, bodywork in good nick, engine running great, no turbo issues like most, doesn't loose oil, gearbox running well...
No heap here...
13 Nov 2006
No heap here...
Why wouldn't it pass an MOT?
Caporegime
23 Dec 2011
Northern England
No heap here...
Ahahahah! Classic.
12 May 2011
Southampton
I am the least mechanical person in the world so today has been a big day for me!
The old golf was coughing and the engine light came on. Plugged in an OB2 reader and got error code P0401 - EGR problems. A new one is £100+, ebay specials £25+. A few Youtube videos later my Dad and I take off the EGR and get it cleaned up using carburettor cleaner (I think) and put back off, clear the engine codes and yay it's been fine since.
Mission 2 was getting started on doing something with my broken BMW. Many many things to do but something easy to start with - getting central locking fixed by sending off the GM5 module to get repaired. Fiddly to get out but not complicated.
You will live again BMW!
