Alpenföhn® Wing Boost 3 RGB
7 Feb 2019
First post so be gentle!
currently have a few noctua NF-F12 fans but... my case just looks dark.... was looking at the
Alpenföhn® Wing Boost 3 RGB fans, cant seem to find a review of them anywhere.
Has anyoneh had luck with them? How do they compare to Noctuas fans?
thank you :)
1 Jul 2011
At a guess they won't work quite as well and not sound as nice either.
Have you considered using something like Phanteks Halos for £11.99 each? Another option is a RGB light strip kit with power supply and remote control in same price range. Google 'RGB light strip kit' for longest strips. Google 'RGB backlight kit' for shorter (150cm) strip usb powered with inline light control.
OP
7 Feb 2019
Thanks for the reply!
The phanteks Halos look pretty good, I dont have any RGB headers on my mobo, Would i need an adapter of some sort?
thanks again :)
1 Jul 2011
thanks again :)
The Halos Lux can be controlled through Phanteks' integrated RGB controls. The bundled RGB-LED adapter can also be integrated with the motherboard, offering support for MSI Mystic Light, ASUS Aura Sync and Gigabyte RGB Fusion. A diffuser ensures a bright and even distribution of light to allow your case and fans to achieve the best possible lighting. Especially exciting is the possibility to daisy-chain several Phanteks RGB products together. The Halos Lux can also be integrated into such a setup.
https://www.overclockers.co.uk/phan...e-bundle-of-3-buy-2-get-1-free-ca-07c-pt.html
Link below is the Phanteks RGB adaptor
http://www.phanteks.com/PH-CB_RGB4P.html
OcUK also sell a Phanteks adapter cable
https://www.overclockers.co.uk/phanteks-rgb-led-adapter-cable-ca-057-pt.html
