Okay, thanks, but the idea is just spray this all over, then rinse it off?
Like, totally no need to touch it?
Yeah autobrite stuff is named as such SP-RIN-TS
spray rinse top seal.
You're not meant to touch it no, but I do just smear it with a detailing mitt to ensure it's covered the whole panel
Do you spray the whole car before rinsing it off or do it panel by panel?
Panel by panel
So can you spray this on a already wet panel then rinse off?
Best way in winter pointless wasting other products on the car. BH foam leave for a while then jet off. Don't even bother drying the car.
Yeah. So before you dry your car, spray this one and then rinse off. Then dry
Exactly this, in this weather / time of year you just let the pre-winter prep do its thing (if you did pre winter prep) and just take the worst of it off.
Weekly foaming and power wash off done, no buckets, no drying, just foam and water.
