If anyone has any thoughts would be good.
Do it, do it, do it!! Buy that monitor!
Not bothered about having the fastest monitor as long as I perceive it to be more responsive than what I have.
BUT....BUT.....RGBSSSSSSSSSSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!!!!!!
Finding something that matches my R.G.B addressable gaming mankini has been tough. But now that search is over and my life will no longer be empty.
Mine arrived today (from a different retailer) with a stuck red pixel in a central location.
I have contacted Gigabyte support as it's very noticable and £535 is nothing to shrug at.
3% (£13.50) cashback.God is punishing you for not buying from OcUK.
What is OCUK's policy on monitor returns anyway?
So this monitor has caught my eye as it pretty much checks all the boxes I'm after - 27", 144hz, 1440p, IPS with G-Sync or something at least G-Sync compatible. Reviews sound good so far, though a lot have mentioned that it is expensive for what you get. I'm struggling to find other monitors with more-less the exact same specs for considerably cheaper.
Anybody mind pointing me in the direction of a few I could compare with?
Cheers!
Also the Acer Nitro VG27OU this has exactly the same panel but comes without H.D.R 400, it has the same support for 10 bit colour but the display is limited to around the 120 h.z. mark using this wider colour range, it displays 8 bit colour at 144 h.z.
I was under the impression that the XV272UP and Auros also needed to be set to 120hz for 10bit colour (which I assume means it's achieved through FRC).
Any idea when these will be back in stock here? @NikTheSHNIK
