- 3 Feb 2014
There's always bloody SOMETHING...
Draining my boiler yesterday, I opened the Schrader valve on the expansion vessel, and water came out! I thought/think it has a rubber bladder inside it, and if so, that has sprung a leak.
What function does the expansion vessel perform, and more to the point, does it matter if the rubber bladder inside it is leaking? If the inlet/outlet is at the bottom, there will still be pressurised air inside it, so can I just leave it as it is, or do I need to get it fixed? I run my system at a cold pressure of about 1.1 bar.
