Anova Precision Cooker - cook sous vide with your iPhone.
21 Sep 2008
somewhere out there!
Hey all, apologies if i have actually already asked this question however if I have I cant find my post.
So a few weeks ago I sous vided two chicken breasts however one came out beautifully juicy and tender whilst the other came out drier and not juicy, I have had this experience with steaks too. Does anyone think its down to how close the one piece of meat is to the anova element? Or is it just down to purely the animal it came from?
Thank you.
SPG
SPG
28 Jul 2010
What temperature and time, ziplock or Vac bag ?
TBh, never had a issue with anything although i do avoid the annova app and use chefsteps timings instead.
18 Oct 2003
Thank you.
Not had this and we use Anova 4 out of 5 days. Make sure water can circulate around all pieces, although to be fair I don't make much effort. Probably just based on the animal. I almost always for for the lowest temperature in the scale offered.
25 Feb 2004
Hampshire
Thank you.
Sounds odd, as long as the water can move around it shouldn't matter, if it happened once I'd say bad batch of meat, but to happen a couple of times sounds like something odd, is the circulator spinning and how big is your container? Definitely sure the bags are sealed properly?
OcUK Staff
12 Jan 2009
OcUK HQ
They were in the same bag. Vacuum sealed rather than ziplock. I think with the steaks MrsS was talking about the issue was more they were different thicknesses from the supermarket, but again I think we cooked them in the same vacuum seled bag. But yeah, the chicken was two peices from the same pack, pretty close to each other in size and thichkness, cooked in the same bag for the same time, and one was pretty tough and stringy (but not dry), the other was really tender and as you'd expect sous vide chiken to be.
Man of Honour
28 Nov 2007
Depends what you want to do. If you're just melting sugar for creme brulees and so on then normal kitchen one is fine. If you actually want to sear meat straight out of the water bath they aren't good enough. You'd want searzall or something. I only have a basic kitchen one and just do BBQ chimney starter for steaks and things when cooking sous vide.
9 Oct 2004
Paris
Bugger my Anova has stopped heating the water up. Went to do 75c poached eggs and it hit 72c but started falling slowly after that :(
It’ll be 3 years old this May so out of warranty. Anyone had the same issue?
15 Feb 2015
Porterhouse just gone in for 2-3 hours at 54c for a medium rare - now onto the triple cooked chips and béarnaise sauce.
Also tried pork chops for the first time cooked sous vide, couple of hours at 65c and finished in the frying pan, definite improvement over the grill but I think I need to drop another 2-3 degrees next time.
9 Oct 2004
Paris
65c? Try 55c next time! Will be insanely juicy and tender
Man of Honour
18 Oct 2002
Yup. I normally do pork loin steaks or tenderloins at 55-56°C. Pork is perfectly fine pink.
Man of Honour
18 Oct 2002
Tried something new today. Half leg of lamb (about 1kg).
Stabbed it and put slices of garlic and small sprigs of rosemary in the cuts, salt and peppered it. It had the bone in so it had a sharp end, covered that with an additional piece of bag and then vac sealed it to stop it piercing the bag.
57.5°C for 7.5 hours. After an hour, discovered that lamb floats. Weighed it down and left it.
Time up, opened and drained the juices. Pulled as many of the rosemary and garlic pieces out as I could quickly. Well torched and served with roastie spuds, steamed veg and gravy from the juices.
Damn it was tender. Never had lamb that soft, even from a couple of michelin starred restaurants. Was fantastic. Still have a good chunk left too. Thoroughly recommended.
