New build, 2700X on an MSI Gaming Pro Carbon.
Went for 3200Mhz Corsair Vengeance RGB Pro memory.
Enabling A-XMP profiles 1 or 2 in the BIOS, results in the CPU fans ramping right up to maximum. The CPU core voltage doesn't change as far as I can see.
In an information box, a message is displayed which says:-
'CPU fan speed will be optimized once memory is overclocked over 2750mhz'
For now I've manually selected the next available memory speed below 2750.
Obviously I bought 3200Mhz memory as it seemed like good middle ground between the higher frequency (and thus more expensive) sets, and standard speeds of days gone by.
Is there a way round this, or stuck with it?
