*** Official Ubiquiti Discussion Thread ***
1 Jan 2008
How has it worked out for you?
Good actually. I started by testing the AP in the same location as the existing router, fairly central, using both bands. I compared the range of the ASUS RT-N56U versus the UAP-AC-LR and the Ubiquity AP definitely has a superior range and performance (particularly when the signal is not its best).
I then disabled the radio on the router and setup the AP as stand-alone. I've been using this for about a week and it works perfectly. I selectively added devices to either 5GHz or 2.4GHz depending on need and typical location in the house. No problems whatsoever.... The router performs well even on ASUS firmware.
As I'm still developing the house and extending downstairs, I will probably re-review this when the work is completed to check the range of the AP in the new rooms, and potentially add another downstairs and re-locate the existing one to better cover the top floor (probably ceiling mount both). Little bit of cabling to do before that, but since it's PoE that makes things more simple.
Overall, very happy. Don't have a need to run the software yet as current needs are basic, but can imagine adding a cloudkey or Pi later on to take this on for me. Also considering a NAS - could run the software on a NAS server perhaps? Something I'd keep on permanently.
18 Oct 2002
UK
Certainly possible, particularly if you use a NAS OS supporting Docker. My Unraid box runs the Unifi controller in a docker that's always on.
Si.
Si.
22 Oct 2002
Melbourne, Aus
I've been running my Unifi kit as my home setup for about a year now and It's excellent (Although I do get a few stability issues). However, I've really been struggling to set up an outbound VPN on my USG. I'm trying to configure it so that 1 device (or range of devices) go to the internet via a PIA VPN, and others just use the default direct path out. There are some posts on the Unifi forums, but I'm not able to get this working properly.
Can anyone provide any tips or sample configuration to help me get this working?
5 Nov 2011
Derbyshire
One of the reasons I won't run a UniFi router is because of this (or the difficulty of doing so). It's about 5 minutes of work with my current MikroTik.
2 Sep 2007
I'm trying to monitor internet drops. Does anyone know how I can view WAN disconnects on my USG? On the IOS app I can see a WAN Uptime but can't see anything via the Cloud Access Portal.
Kol
Kol
Man of Honour
8 Jan 2003
Ashby-de-la-Zouch
What's an OK go to for an outdoor AP? I see the AC Mesh is suitable for outdoor. Does this operate just like any other AP, similar to my AC lites? I've got one AP at the front of the house, one at the rear, both set to 'low/medium' power. I'd like an AP at the end of the garden where we will have a seating area, about 90feet from the AP at the rear.
I'm running power and data, one solution is to mount another AC lite in the shed which will be down there, but there isn't one and it's not a priority as I've got one shed near the house already. I'd rather just have a weatherproof AP.
Is my only option the AC Mesh in this case?
5 Nov 2011
Derbyshire
UAP-AC-M or the UAP-AC-M-Pro but to be hones tthe normal UAP-AC-M's are fine. They have a really good range on them outdoors. The pro's are probably only useful if you are meshing.
7 Aug 2003
Bristol
Hi All
I've got a unifi 16XG setup
But I seem to be getting weird speed issues.
I've got 2 VM hosts.
1 Connected via Fiber X-520 card the other X540-AT2 rj45.
The NAS (Synology 1817+) has a X520 card also (on the compatible list) with 2 connections one Fiber and one DAC (Different IP Addresses at the mo as i really want to use the fiber as i want to move the NAS from the loft.)
VM1 is on Host 1 (Windows)
VM2 is on Host 2 (Windows)
both host and the NAS are on the same switch.
Fiber modules in the 16XG are Ubiquiti Multi-Mode FiberModule 10G - UF-MM-10G
Fiber modules in the X-520 are from FS.COM and are Intel E10GSFPSR Compatible 1000BASE-SX SFP+ 850nm 300m DOM Transceiver Module (Intel E10GSFPSR compatible)
I'm not worried about hitting 10GB speeds as the VM Hosts are older but you can see the difference between the DAC and Fiber ports of the NAS.
Iv tried different fiber patch cables and the same speed is present.
IPerf Stats
[ 5] local NAS_DAC port 5201 connected to VM1 port 49472
[ ID] Interval Transfer Bitrate
[ 5] 0.00-10.02 sec 2.61 GBytes 2.24 Gbits/sec receiver
[ 5] local NAS_DAC port 5201 connected to VM2 port 49317
[ 5] 0.00-10.02 sec 3.65 GBytes 3.13 Gbits/sec receiver
[ 5] local NAS_Fiber port 5201 connected to VM2 port 49323
[ 5] 0.00-10.02 sec 304 MBytes 254 Mbits/sec receiver
[ 5] local NAS_Fiber port 5201 connected to VM1 port 49332
[ 5] local VM2 port 5201 connected to NAS_DAC port 48055
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-10.00 sec 5.11 GBytes 4.39 Gbits/sec receiver
[ 5] local VM1 port 5201 connected to NAS_DAC port 40415
[ 5] 0.00-10.03 sec 2.84 GBytes 2.43 Gbits/sec receiver
[ 4] local VM1 port 49564 connected to VM2 port 5201
[ 4] 0.00-10.00 sec 3.49 GBytes 3.00 Gbits/sec sender
[ 4] 0.00-10.00 sec 3.49 GBytes 3.00 Gbits/sec receiver
[ 4] local VM2 port 49566 connected to VM1 port 5201
Any Ideas
Rob
Man of Honour
20 Sep 2006
What's the MTU size all round and are jumbo frames enabled on the switch? What's OS is the host, is it Windows or is the VM Windows?
Are the fibre connections the right specification for the transceivers?
7 Aug 2003
Bristol
Currently set to 1500MTU on the VMWare boxes and the NAS the Switch(s) all have jumbo frames enabled. Iv had the switches a week and a bit so im doing changes slowly to make sure all works.
The Fibers are 10m OM3 LSZH 50/125 LC/LC (so i think so, but could be wrong.)
Man of Honour
20 Sep 2006
I'd look into hardware offloading and if it's enabled on the fibre card within the Synology OS. What's the CPU like on the ESXi servers and the Synology when you test fibre?
Something is not quite right.
Enable 10 Gbit all round and you should see line rate throughput on the DACs.
7 Aug 2003
Bristol
The synology is so locked down you have options to see if anything is enabled.. As far as i can tell the synology should be good to go out of the box. The card is compatible. The fiber and the DAC are detected (the other Fiber SFP+ modules i have are rejected by the card / synology so i'm pretty happy that's ok.)
The DAC is a juniper one or a cisco one i cant remember.
VMware.
Box1 is a dual X5675 with 144Gb RAM. 8% cpu 2 VCPUS in the guest. the host next to nothing.
Box2 is a C2750 with 64Gb RAM.
esxcli system settings advanced list -o /Net/UseHwTSO
Path: /Net/UseHwTSO
Type: integer
Int Value: 1
Default Int Value: 1
Min Value: 0
Max Value: 1
String Value:
Default String Value:
Valid Characters:
Description: When non-zero, use pNIC HW TSO offload if available
7 Aug 2003
Bristol
Setting the MTU to 9000 seems to make matters worse if anything. speed 2.89Gbits/sec on the DAC from 3.65Gbits/sec
and a slight improvement on the Fiber to 762Mbits/sec from 254Mbits/sec
All from VM1 to NAS
7 Aug 2003
Bristol
No errors that i can find..
Code:
PORT    NAME    LINK STATUS    TX SUM    TX BYTES        TX FRAMES    TX MULTICAST    TX BROADCAST    TX ERRORS         RX SUM        RX ERRORS    TX TPUT     RX TPUT
2        ESXI 2    10,000 FDX    2.21 TB    2425301989986    2153713192    18210737        99586777        0            2.17 TB       0            64.2 Kbps   0 bps
3        ESXI 2    10,000 FDX    108 GB     116272418338     90363808      409388          2271755         0            179 GB        0            711 Kbps    982 Kbps
4        NAS_FIB   10,000 FDX    39.8 GB    42734277257      33474262      828592          2342512         0            61.8 GB       0            69 Kbps     7.67 Kbps
7        NAS_DAC   10,000 FDX    9.08 TB    9985046729794    7886329637    32046553        103389469       0            6.67 TB       0            18.5 Mbps   232 Kbps
11       Uplink    10,000 FDX    1.37 TB    1503064608919    1443439516    16385335        4052956         0            7.02 TB       0            121 Kbps    18.8 Mbps
12       ESXI1     10,000 FDX    3.29 TB    3615658647653    2505710652    1094224         2740728         0            538 GB        0            69.8 Kbps   0 bps
Man of Honour
20 Sep 2006
All from VM1 to NAS
Did you set MTU all the way through? So the virtual switch within VMware and the MTU of the VM itself?
