Hi,
Thinking it is time to upgrade my graphics card. It is a GTX 960. Don't want to spend a huge amount, £150-£200.
No preference for new or second hand.
Just 1080P single screen use - but play games like Tomb Raider, Elite Dangerous and IL-2.
Was thinking of sticking with nvdia but will consider AMD for a better solution.
My research is suggesting that a GTX 1060 is going to be the best for my budget, may hit lucky with a second hand 1070 but would have to be in the right place at the right time. Any higher nvdias are going to be out of my budget.
BUT not looked at PC components for a long time, and not familiar with the AMD range - what AMD card would I be looking at for my budget and how would it compare with the GTX 1060.
Appreciate any advice.
Cheers,
Nigel
Cheers,
Nigel
