So . . Any one with a bykski decipher the instructions?
Your image is broken Pete, but glad to hear all is well.Yeah me, finally got round to putting it on today
Just a FYI, the original back plate fits too
The pictures make no sense at all, it's annoying.there is a bykski utube video online which might help if you never fitted a GFX water block before. the instructions are chinese!
Nailed it, I was over thinking it completely. 2000mhz 1200mhz core 34.c Junction 60.c absolutely over the moon about this.
Whats the highest anyone here has gotten the core or the ram, and what mv's did you use?
Mine is at the local deliver depot, in thinking it will deliver tomorrow...?
Resize it to around 800 horizontal then upload it, Example -
Any excuseAnd stop nicking my tyre caps Dom or else!!
Your image is broken Pete, but glad to hear all is well.![]()
With a horrific overclock it's gets to 40.c and 65-70 junctionOdd as works for me, anyone else not see it ?
What's the temps people getting under water, Mine appears high compared to what the 64 run at.
Superposistion makes it hit high 60's .
I've reseated it twice too.
Bykski chinese block of awesomeness picture a few posts backWhat block you using ? Though that shouldn't make that much difference![]()
