Z390 VRM Coil Whine
27 May 2008
I've been considering moving to the Z390 platform, but I've read a fair few posts and user reviews complaining about VRM coil whine. A wide range of manufacturers and models are mentioned (particularly Gigabyte Aorus and lower/mid Asus).
Is this genuinely wide spread or are these people just unlucky?
I'd never heard of coil whine on a motherboard before. I've experienced coil whine from the GPU at load, but at least you can drown it out in games. Putting up with it when I'm doing basic work would drive me to distraction and puts me off forking out a reasonable sum for an upgrade. I've read some people have had various degrees of success disabling C-states, but that doesn't seem like a very elegant solution (and shouldn't be necessary).
Thanks for your thoughts.
1 Dec 2015
get a bit of whine, run stress test tools for 4-5 hours, caps should bed in a little and coil whine should ease up, if you happen to get a board that does and the method suggest it doesn't then RMA - gigabyte rep on here as well which greatly helps
@GIGA-Man <<<<
OP
27 May 2008
Thanks for the replies, something to think about.
The Aorus seems to get such good reviews, yet it seems to get the most complaints about coil whine. How bad are the Gigabyte UD or Gaming X? I know their VRMs are inferior to the Aorus, but are they good enough for a stock 9700k?
5 Mar 2004
Southport
I've got an 8700k all cores at 4.8Ghz without any hassle. The UD was made for a 9700k, it's a bit no frills but it's a great board.
9 Nov 2005
manchester,uk
Yeah any of the Gigabyte Z390 boards will handle the 9700K just fine. The entry level Z390 UD will even handle the 9900K albeit at stock or with a mild overclock. There is a video on youtube from Hardware Unboxed and he couldn't get the Gigabyte board to thermal throttle with a 9900K although it was running very hot on the VRM's.
1 Dec 2015
actually, can take something like 600 amps compared to Aorus Master's 400amps- if you want to get technical . what the difference is, is the quality of the phase unit and its power delivery .
all cores boards have been designed to run 9900k without throttling ! Aorus boards been designed to do it with high overclock, and Master to run AVX loads 24/7
OP
27 May 2008
Merci. I'd been reading quite a lot about (inadequate) VRMs on Z390s and it's not something I'd really worried about for stock systems in the past - but some of the reviews had made me wonder! Don't really see the point in spending more than I have to if I don't plan to overclock (lack of time, more of a set and forget guy these days...).
28 Jun 2017
Coil whine is only a problem if you sit with your head inside the case, listening for it.
It's like people complaining about a rattle in their car - guess what, EVERY car has some sort of a rattle.Just turn the radio up a bit and get on with your life. :)
3 Mar 2009
Bugger, got my Z390 Auros board a couple of days a go and could immediately hear the coil whine on the desktop (no head in case here!), different PSU and also removed GPU, sound was still there, now I learn this is something many of these boards suffer from? Just my luck :p So what have people been doing, RMA'ing and hoping the replacement doesn't suffer from it?
1 Dec 2015
ran Asus Real bench for 1-2 hours ? like GPUs whine can be lessened via stressing the boards and caps .
OP
27 May 2008
Seems on Reddit that RMAs have solved for some, but not others. The whine appears to be related to C-states though, some people have got rid of the whine by disabling all C-States, others just C1E. A bit of a crude fix, but it's not uncommon to disable them if you're overclocking I suppose.
3 Mar 2009
Not that specific one no, but ran OCCT stress for just over 3 hours, can still hear the whine.
Hmmm, only tried the C1E off so far, sadly it still whines. Might try the rest.
Bit annoying really, if it happened during gaming I probably wouldn't even notice over the fan noise. As it happens while doing nothing on the desktop, its far more annoying.
OP
27 May 2008
Did any of the other C-state settings help?
3 Mar 2009
I tried with C1 state off, no change, then I turned every single C state off, and that actually did stop the whine. But im a bit of a tart and dont like the idea of having to do that, so it's gone back for an RMA today anyway (there was another issue with restarting the machine too).
