Petrol station
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
All the Shell garages that I use all have short reach and some people are idiot and don't pay attention that there is one available in front and cba to manoeuvre around.
I tried pull the short hose at Shell once, but it recoiled back really sharp and the force yanked the sprout thing out of my hand and almost hitting the car.
20 Feb 2004
Hondon de las Nieves, Spain
This, and also the selfish c-words who don't wait that extra 30 seconds for the person in front to get back to their car from paying so that they can move to the front pump rather then jump straight on to the empty pump and block off an empty pump for the duration of their fill up.
Usually there's room in between both sides to make it to the front pump. Although there is a place in hell for people who park miles away and block that off!
1 Apr 2003
Northamptonshire
I always giggle at the people who are already queuing when I arrive, I go straight to an empty bay fill up, and I'm off and they're still queuing :D
I tend to fill up at Shell and I've yet to find a hose that's dirty or that wont reach.
9 Apr 2007
I fill up at Costco at 6am 90% of the time I'm the only one there. It's like heaven, no waiting, especially no waiting for those people that do a bit of shopping while paying.
It's all pay at the pump as well, it's how all fuel stations should be.
Jez
Jez
Caporegime
18 Oct 2002
I never understand people that wait, i have driven all sizes of cars and even a full size Range Rover has no issues ever with the pipe reaching to the far side. Just park infront of the desired pipe and it goes around the back easily on every car.
13 Mar 2007
South Yorkshire
I use either being in a smaller car but some of the pumps I've used that isn't my local Shell don't have much length to pull it to the 'wrong side'. Once they've had newer pumps installed they appear to have been designed with upto 3m reach.
Caporegime
29 Jul 2011
In acme's chair.
I must admit that I do this. I cba with wrangling the hose around to the other side of the car, and my time isn't so precious that I can't wait 45 seconds. :p
That said, not all pumps have long reach hoses. The local Tesco filling station has two rows of long reach hoses and the other 5 or 6 rows are short and you would struggle to get to the filler cap on the other side.
8 Nov 2003
Bedfordshire
Park so the hose is in line with the rear bumper (and closer to pump), walk backwards straight with the hose behind car, move desired length along hose to bend so the nozzle can reach the filler. Fill up car without hose ever touching car. Get lots of angry looks from people queuing because they are too stubborn to realise they can use both sides.
1 Apr 2003
Northamptonshire
This!
Caporegime
20 Oct 2002
It depends if the car in front left enough room for you to move that far forward.
13 Jan 2012
n.wales Rhuddlan
The few times i have tried despite parking as close as possible only once would it reach and it was not fully inserted so i gave up trying and just wait, Sadly this is just another punishing fact of owning a zafira.
30 Sep 2003
Norwich
I once managed to get the nozzle stuck in the fuel filler because it was so tight from being pulled across :o It did come out eventually but I had visions of the hose coming off the pump from me having to pull it so hard and me featuring on the next episode of "Caught on Camera" from the CCTV footage :o. I've also been swiped by a car squeezing down the middle of the lanes so I'm a waiter these days.
Not a problem at all at my local Shell because the lanes are 1 car wide with a pump on either side so only the two end lanes have the possibility of having to pull the hose across.
Jez
Jez
Caporegime
18 Oct 2002
Indeed, as i mentioned above, i have never been to a pump which couldnt reach even a full size Range Rover on the "wrong side". There is no way that it wont reach on something like a Zafira :p
18 Oct 2004
Kent
At half the stations round here, your front bumper would now be blocking the exit route for up to 11 cars and two HGVs... well done.
Are you driving a stretch limousine, or is Reading just blighted by particularly badly designed forecourts?
I've parked at hundreds of pumps with the back of the car level with the hose to make it easier to pull around the car - not once do I recall ever being close to having the front of the car protruding enough to be an obstruction, even in the larger of our two cars (and yes, not being ignorant, I do check).
