Caporegime
It should do, its new
2700miles, getting oldIt should do, its new
Managed to 'remap' the wife's S-Max from 140bhp to 163bhp for free today. Ford sold 2 versions of the 2.0 TDCI S-Max at the time and they are mechanically identical in every way - same engine, same turbo, same intercooler, same injectors and the ECU even has maps for both variants on it. It was as simple as using FORScan to change the engine type in the configuration and telling the PCM to relearn vehicle data after. There's a definite difference after so can't complain for free.
What the hell am I looking at, what car is this?
Had to change the battery
Doh, no idea why I couldn't figure that out! I saw the Audi grille and the lack of front engine, and couldn't think of an Audi without a front engine...
Yep it will be the same on the Mondeo too. As long as it's definitely the DW10C Euro 5 engine which was used from (I think) 2010 onwards. I gave it a try after reading this thread on Talkford:
https://talkford.com/community/topi...-201009-140-to-163-hp-by-elmconfig-ids/page-5
At first I thought it was only possible with Ford IDS but it is definitely possible with FORScan with the extended license and a Ford HS/MS CAN OBD cable
Took car to garage. They said 3 hour job.
Called me, wrong parts arrived, went to collect, cars not ready till tomorrow.
Bah
Took stock rear spring pads out. Fitted custom 'thin' spring pads. Now the car sits more level.
No idea why most suspension kits lower the front more than the back, it looks crap.
It's so when you have people in the back it sits somewhat level.
