Because you are talking cobblers?
Ok, I see, so you simply ignore the performance comparison charts and think that Ryzen 3000 is the mother of it all. It's not. And I don't like it because it has its own traits.
You are clutching at straws my friend. If you are so sure you can get the same performance from a 1700 then go and buy one. What I wouldn’t do is try to convince others that a 1700 offers remotely comparable performance to a 3700X.
Hence the reason for his insane mental gymnastics to justify his arguments.
My mind is Pretzeled just reading it
Well, Ryzen 7 1700 offers 50% or more better performance per dollar which is my point. https://www.techpowerup.com/review/amd-ryzen-7-3700x/22.html
Ok, the price for a 1700 is low 200’s the price for a 3700X is low 300’s that is the reality.
That £100 saving will pale in comparison to the expense of building a 4K gaming system and a Ryzen 1700 is going to offer significantly less CPU performance than a 3700X. That is my point.
Is the difference in performance worth the price? Well to me I’d say it is.
Gpu A does 60fps at 4K
Gpu B only does 60fps at 4K
Gpu A costs 40% more than B
How ever he is wrong in every other way.
You would buy gpu B, the cost of GPUs is shooting up each year. And today gpu A is ok in 12months it will not be ok.
The same should be said for his cpu choice. But it's no because a 6700k can still game at 4k, the 1700 will be ok for a year or 2
I am not wrong about anything. Actually, you are the one calling the black white![]()
Nope. The 1700 cpu is good for the one example you have shown. In ever other test and situation the 3700 is better. And as bios's get better and your can push ram passed 3600mhz the 1700 will just fall behind more
3700X is almost 3 times more expensive! 3 times! More expensive. You can buy 1700 for 134 pounds.
The price difference between a 1700 and 3700X is about £100.
He comparing used 1700 to new 3700x..
I did see one sell for 145 last week.. but to be fair I would not buy a 1700 the performance just isent there, buy a 3600 if money is a problem
