hi as the titled says i got a ryzen 3700x to replace my 2600 in my msi b450 motar motherboard but after updating my bios to the latest 1.9 firmware i discovered my motherboard has overclocked it to 4.3 across all cores iv been through the settings and the only setting i can see is precision boost is set to on by default and my base clock is set to 3.6 with no tweaks added to the settings anyone else have this problem as i thought ryzen cpu scale up and down by default temps are between 45-50c while idle and 50-60 when gaming
