- 7 Oct 2008
Hi and thanks for taking the time to read this.
About 6 years ago I spent over 5k on a high end gaming rig based on X79, Asus Rampage extreme and with dual GTX Titans as the core components.
Lately I have been having trouble with the system and have narrowed it down to the MB but as its going to be difficult to replacethe MB at this point I have decided to bite the bullet and upgrade the system.
I will be retaining the following components:
Coolermaster CM Cosmos S case
EVGA 1kw PSU
2 x early gen SSD drives (will convert to data drives in new build)
DVD and peripherals
I mainly game on a 2500x1600 Dell 30'' having stopped using my 50'' 4TV some time ago, I was a very early adopter of 4k however the screen size just ended up being too big for me as i sit relatively close to the screen area.
Moving forwards I will be purchasing a 32 to 34 inch true 4k monitor and so will be reverting back to 4k gaming, my experience gaming at 4k is that my dual Titans could handle it easily at playable frame rates of 40-100 depending on game and settings and I have researched a LOT on whether to change the cards out for maybe a single RTX2080Ti but even though the newer card is better in many situations it seems a bit pointless because its a lot of money for something I dont actually need seeing as the Titans can produce good FPS already.
For the rest of the system I am looking at this:
Asus ROG Rampage VI Extreme 2066 X299 MB
Corsair vengeance RAM 2x16GB (so I can upgrade to more later if I want to, old system has 64GB)
Intel I9 9900x CPU
CM Masterliquid CL240R liquid cooler
Win10 Pro
Total cost of the new components is just under £2400 from my budget of £2500
Can anyone advise if having my old GTX Titans in this new build will cause any problems and/or if there will be any bottlenecks either way. Note that I am not any kind of expert overclocker and will be running the Titans at stock and the CPU's at a mild overclock using the inbuilt Asus bios software
Many thanks in advance
EVGA 1kw PSU
DVD and peripherals
Aorus 1TB NVMe PCIe Gen4 M.2 Solid State Drive (would like to use as system drive
)Intel I9 9900x CPU
Win10 Pro
