G.Skill trident z neo
24 Feb 2010
Yeah same ic I think. Us higher quality pcb. Should be late this month for stock...
@8 Pack How tall will the new 3600-C14 kits be? Same height as Dark Pro kits or the taller Xtreem kits? Currently have the 3866MHz kit on order with 3900X pre-order but happy to wait and swap to 3600-C14 kit.
16 Sep 2018
When/if it's still a thing i hope it's cheaper than the Neo CL14, even though they claimed it was going to be in shops by the start of august i guess it got delayed and prices have only just started to be listed, but at £280 for 16GB they're taking the widdle.
16 Sep 2018
News if OCUK has some on order you mean?
They're available in general but you'd have to look yourself due to the no competitor hinting rule, if @8 Pack could provide an update on the 8Pack 3600mhz c14 that would be nice as the prices for the Neo CL14 stuff are ludicrous , if it's not going to be possible to get 3600mhz CL14 for a more reasonable price i may as well pull the trigger on some 3600mhz CL16 sticks.
16 Sep 2018
Then all i can say is you've not looked hard enough.
e: What speed and CL was you looking for?
E2: You've blocked conversations. :(
20 Oct 2010
I am also looking to build a new ryzen pc and was looking at these babies but cannot find them in the UK. I found a 32gb 2x16 3600mhz cl16 (with 16-19-19-39 timings) and not sure if i should go for that or wait for OCUK to bring anything that has better timings. Would it matter much with better sub timings ? I am a complete noob with timings i am still on DDR2 on my main pc.
5 Jan 2019
Anyone have info on when the g.skill trident z neo will be available to purchase in the UK?
The modules I'm interested in are the 32gb -3600 CL14-15-15-35
Cheers.
I got mine from Newegg online.
Bough 16GB 3600Mhz CL16 for £153 in total.
Ordered on a Monday evening, arrived on the Wednesday morning!
16 Sep 2018
It's rather odd as I've been seeing more European etaliers listing the CL14 sticks, obviously for ludicrous prices, but so far not a single stockist in the UK. :(
I would be handy if @8 Pack could provide an update on the following...
Not sure on gskill. 8Pack 3600mhz c14 available soon. We have been working on this a while....
But ofcourse no rgb on 8Pack for top qudos!!!
Before the G.Skill sticks come into stock in the UK, assuming they will, as spending £300-280 (converted from Euros) would be a bit sickening if a week later OCUK start stocking the 8pack sticks.
Man of Honour
26 May 2012
well yes, unfortunately.
get micron e-die and do it the old fashioned way...yes, i freely admit that b-die is inherently better ram, but it's also double the cost.
what do you get for double the cost? it certainly isn't double the performance that's for sure...hell probably not even an extra 5% performance.
maybe you get smallerlatency numbers and a bigger epeen sure...but i'd rather have the money saved in my back pocket, than in someone else's
£150 for 2x16gb sticks running at 3600 16-18-12-12-32
with tuned settings, the performance difference is minimal
28 Sep 2018
The kits are available from certain retailers now, but don't expect a bin such as CAS14 3600 to be cheap. That kind of binning doesn't come easily. Hence why the OCUK range isn't available just yet.
A decent bdie can hit that manually tuned for daily. Limited by your IMC.
I doubt many people on a gene/apex/dark would have much issue tuning c14 3600 on bdie.
