Painting Fresh Plaster - Help a noob
18 Oct 2002
I can't remember the exact ratio, but when I had a room skimmed a few years ago I was told to just buy the cheapest white paint and water it down with whatever ratio they suggested at the time and apply several coats before decorating properly. The only issue I've had is paint flaking off behind a radiator and I'm not really sure how to stop it happening again in the future when I paint again behind the radiator.
did you put the radiator back on quite quickly and then use it? force-drying is not good for paint
28 Nov 2002
Cumbria
remove the rad, lightly sand the flaky paint off, re prime area then re paint when dry, don’t warm radiator until paint is fully dry
28 Nov 2002
Cumbria
I started priming my walls with watered down cheap emulsion but then paid extra for fresh plaster emulsion , when I say extra it was a few quid if that. It’s taken the hassle out of getting the consistency right and the extra time messing about. If you’ve paid thousands to re skim/plaster your house then why quibble over a few extra quid on paint :/
Man of Honour
OP
24 Sep 2005
Thanks all for the advice. Seems to be a consensus that basic emulsion (not the cheapest) will do the job. I’ll let you know what I get and how it goes! :)
28 Nov 2002
Cumbria
This is the key surely, your buying cheap rubbish. I mean mixing some paint with the correct amount of water isnt hard, but if you start with a poor quality product you will get a poor finish.
Cheap doesn’t necessarily mean rubbish, I just personally found the extra step in diluting it a waste of my time when I could buy it premixed for just a couple of quid more
28 Nov 2002
Cumbria
you’ve spent money getting the walls plastered, will spend money on your finishing paint and other things, why bother diluting anything when there’s paint already premixed for the job at hardly any extra cost just to save a £1 or 2
25 Oct 2009
Caerphilly
What are you buying that is only £1 or £2 more expensive? It's considerably more expensive from what I've seen!
28 Nov 2002
Cumbria
Figure of speech, but last time I bought some I didn’t find it much more expensive ,considering I’d just paid quite a few thousand to have the house fully replastered , it didn’t make sense to start worrying about saving on a few litres of paint
13 Jun 2009
My own head
Surprised no one mentioned Dulux Supermatt. The coverage on that was amazing. If your paint was flaking off from decorating I can almost guarantee that the plaster was too smooth.
