- 24 Aug 2015
time to upgrade now or wait for the 10 series? Just got off a 3 hours resident evil 2 binge (which is amazing) checked hw monitor and looks like my 6700k is struggling to keep up with the card however Im not sure if its acutally bottlenecking or not?
everycore was 100% maxed but the gpu was also 100% I thought bottleneck were 100% cpu but low gpu use? Im running at 1440p if that makes any differance,
temps are all good highest core 69 lowest 62, however my aio is 5 and a half years old now and was thinking of replacing it since it can go a bit crud inside and also now the warranty has also expired, the temps were awful but I replaced paste and that seemed to keep it ok for now, if I replace that was wondering if it was worth replacing the mobo and cpu too if the cpu is a bit dated now and holding the card back
Thanks for any replies
