2 NVMe SSD's
21 May 2018
South Wales
I have a B450 MSI Gaming Pro Carbon and already have 1 NVMe SSD installed and looking to add another, will it impact my system performance having 2 installed?
Here's the blurb from the manual:
1x PCIe 3.0 x16 slot (PCI_E1)
Supports x16 speed with AMD® Ryzen™ 1st and 2nd Generation processors
Supports x8 speed with AMD® Ryzen™ with Radeon Vega Graphics processors
Supports x4 speed with AMD® Athlon™ with Radeon™ Vega Graphics Processors
1x PCIe 2.0 x16 slot (PCI_E4, supports x4 mode)*/ **
3x PCIe 2.0 x1 slots*
* PCI_E2, PCI_E3, PCI_E4 and PCI_E5 slots will be unavailable when installing
M.2 PCIe SSD in M2_2 slot.
** PCI_E4 will run x1 speed when installing devices in any PCIe 2.0x1 slot.
AMD® B450 Chipset
4x SATA 6Gb/s ports
1x M.2 slot (M2_2, Key M)*
Supports PCIe 2.0 x4 2242/ 2260 /2280 storage devices
AMD® CPU
1x M.2 slot (M2_1, Key M)**
Supports PCIe 3.0 x4 (AMD® Ryzen 1st and 2nd Generation/ Ryzen™ with Radeon™ Vega Graphics) or PCIe 3.0 x2 (AMD® Athlon™ with Radeon™ Vega Graphics)
and SATA 6Gb/s
Supports 2242/ 2260 /2280/ 22110 storage devices
2x SATA 6Gb/s ports**
** SATA5 and SATA6 ports will be unavailable when installing a M.2 device in
M2_1 slot.
This would indicate that you'd loose all other pcie slots while using the 2nd slot
PCI_E2, PCI_E3, PCI_E4 and PCI_E5 slots will be unavailable when installing M.2 PCIe SSD in M2_2 slot.
I'm not 100% sure but it's doubtful. Don't see the point in the manufacturer doing that.
I understand that the primary is v3.0 and secondary is v2.0 from what I'm reading, would I still get great performance from my choice of SSD on that slot? I'm aware it might not achieve it's rated performance but shouldn't it be faster than a regular 2.5" SSD SATA drive?
I would be surprised if you even noticed a difference between them to be honest. They will both run at x4.
