Hi,
One of the biggest component manufacturers have decided they fancy a go at the All in one liquid cooler market and boy they have not disappointed. The new Aorus AIO Cooler looks amazing with it's *Cough* RGB Fans and customisable digital display.
The design of this cooler has some really interesting features with a customisable display which we have seen before but Gigabyte have made this look even better. The display allows you to change the image to whatever image you want with it's editor but the default options look just as good.
The dual ball bearing high performance fans come with addressable RGB to allow multiple colour options. The fans support RGB FUSION 2.0 and have the ability to synchronise with other AORUS devices. The fans have been designed with noise level in mind keeping the range at 18 - 39.5 dBA.
Available in 240mm, 280mm and 360mm radiator sizes.
The Aorus coolers perform very well and look amazing so if you are in the market for a new cooler I highly recommend these. Check them out below.
Gigabyte AORUS 240mm RGB Liquid AIO Performance CPU Cooler @ £159.95 inc VAT https://www.overclockers.co.uk/Giga...uid-AIO-Performance-CPU-Cooler-HS-00A-GI.html
Aorus AIO Cooler, 240mm Design, Dual Ball Bearing ARGB Fans, RGB Fans and Pump Display, Digital Display, 3 Year Warranty, Compatible with the latest Intel and AMD Sockets.
Specification:
Radiator & Block:
- Dimensions : 272 x 121 x 27mm
- Pump Dimension : 80 x 80 x 60mm
- Radiator Material : Aluminum
- Block Material : Copper
CPU Socket:
- Intel 2066, 2011-3,1366,115x
- AMD TR4, AM4
Fan:
- Spec : 2 x 120mm ARGB Fan
- Speed : 2500 RPM +/-10%
- Bearing Type : 2 Ball Bearing
- Air Flow : 59.25 CFM
- Air Pressure : 3.51mmH2O
- Life Expectancy : 70,000 Hours
- Noise Level : 18 ~ 39.5 dBA
Software:
- RGB FUSION 2.0 support
- AORUS ENGINE support
Warranty:
- 3 Years
Only £159.95 inc VAT.
ORDER NOW
Gigabyte AORUS 280mm RGB Liquid AIO Performance CPU Cooler @ £184.99 inc VAT https://www.overclockers.co.uk/Giga...uid-AIO-Performance-CPU-Cooler-HS-00B-GI.html
Aorus AIO Cooler, 280mm Design, Dual Ball Bearing ARGB Fans, RGB Fans and Pump Display, Digital Display, 3 Year Warranty, Compatible with the latest Intel and AMD Sockets.
Specification:
Radiator & Block:
CPU Socket:
- AMD TR4, AM4
Fan:
Software:
Warranty:
- 3 Years
Only £184.99 inc VAT.
ORDER NOW
Gigabyte AORUS 360mm RGB Liquid AIO Performance CPU Cooler @ £199.99 inc VAT https://www.overclockers.co.uk/Giga...uid-AIO-Performance-CPU-Cooler-HS-00C-GI.html
Aorus AIO Cooler, 360mm Design, Dual Ball Bearing ARGB Fans, RGB Fans and Pump Display, Digital Display, 3 Year Warranty, Compatible with the latest Intel and AMD Sockets.
Specification:
Radiator & Block:
- Dimensions : 394 x 120 x 27mm
CPU Socket:
- AMD TR4, AM4
Fan:
- Spec : 3 x 120mm ARGB Fan
- Air Pressure : 3.51 mmH2O
- Noise Level : 18~39.5 dBA
Software:
Warranty:
- 3 Years
Only £199.99 inc VAT.
ORDER NOW
Specification:
Radiator & Block:
CPU Socket:
- AMD TR4, AM4
Fan:
Software:
Warranty:
- 3 Years
ORDER NOW
Specification:
Radiator & Block:
CPU Socket:
- AMD TR4, AM4
Fan:
Software:
Warranty:
- 3 Years
ORDER NOW
Specification:
Radiator & Block:
CPU Socket:
- AMD TR4, AM4
Fan:
Software:
Warranty:
- 3 Years
ORDER NOW
