Caporegime
You’ve only posted 4 tips from your top 5.
I think that's part of the joke.
I know it’s mag being his usual self.I think that's part of the joke.
Don't **** and fall back in it
One proper life hack coming up:
If you want to remove permanent marker, colour over it with non permanent marker. Then, simply rub not one but both out.
You, my friend, are welcome.
Then you have to find non perm marker which you might not have... But everyone has hairspray in the house (or a colleague does at work). Spray hairspray onto perm marker and wipe, It will remove all marker ink off any solid surface.
As for another actual lifehack, crunchy peanut butter will remove scratches and scuffs on car bumpers and non metallic panels.
Well I do actually have a ‘life hack’ that I wanted to share but it was so lame that I didn’t think it was worthy of posting anywhere... UNTIL NOW
When you have had clothes for awhile sometimes they end up being a little smelly after you wear them for a shorter period of time (‘cotton sweats’) I think. I had tried to get around this by washing older clothes at a higher temperature to kill the residue bacteria or whatever it was. Sort of worked.
Out of nowhere, we got a tip from a laundry pro to use a product called Zoflora (?!) and put a cap in your washing... what is this voodoo...
Well, it’s this but you can get it at ASDA.
https://www.amazon.co.uk/Zoflora-Co..._a_1_7?keywords=zoflora&qid=1574586394&sr=8-7
Have only used it a few times but holy poop, it’s awesome! Clothes smell so fricking clean like never before. Definitely recommend this! Pretty sure it’s a generic disinfectant but meh
Beads?I don't think you bees the qualifier before American.
