- 13 Apr 2013
- Scunthorpe
Ok thanks
Not sure to be honest. I would not want to go past 1.325v myself.
Never looked those graphs or logs to be honest.Before I forget to ask, when testing did you get a max voltage note from the graphs/logs to indicate what the auto boosting was providing it? Thinking along the lines of if it works fine before manually setting voltages you know what the board was pouring out as that would be a safe 24/7 amount.
Would a 3600 be better than 3770k at 4.6ghz in games? 1440p?
sweet thx, well i originally thought it would be ok but i read so many bits of conflicting info so didnt want to risk it. yeah after i had finished on the cpu i was going tighten the timings.Go for the 4.3Ghz. 1.35v is fine, hell my 3600 runs at 1.38v stock under all core load. You should try tightening them ram timings up, that will give you more of a performance boost in stuff like games over a few Mhz on the core.
If you watch these videos, you'd see that the framerate difference is not big:
He scours the web looking for examples that fit his narrative and then posts it here. Lol. He has been proven wrong by loads of users here yet he continues. He does not seem to get it is not black or white case and there is plenty grey and advice must be tailored to an individuals use case. Saying a 3600 is not enough for anyone is looney.Firstly, why no GPU load in the OSD? if the GPU is under high load then the performance difference seen here is invalid, secondly the "Extreme OC 3770K" rig is clearly running much lower graphics settings
This is a shill channel. Just so you know... if you go looking for things to confirm your own bias, its the sort of thing you will find.
He even tried to tell me that a Ryzen 3600 is not good enough for me as 4K60FPS user and I need at least a 8 core CPU. Obviously I did not listen and low and behold my 3600 barely warms up when I game. I mean how could that be true when my 4770K did not even get 50% usage and that is a 6+ year old 4 core CPU with worse IPC. I am always GPU limited or hit my FPS target way before ending up CPU limited.
Yeah ^^^^ i went from a 4.6Ghz 4690K to a Ryzen 1600 and found anything from +0% to over 2X better performance, the 3600 has given me 30% on top of that.
Depends on your GPU and the game.
0% in games and 100% in productivity loads. Very weird upgrade, TBH!
If I were you, I would have been with a Ryzen 7 2700X and Radeon RX 5700 XT![]()
Yeah, makes no sense does he? He makes comments like that and when I call him out on them as they make no sense I get my name put onto his sigYou have a time machine to have got the 2700x prior to the 1600 and that would have been your advice to use said time machine.....right![]()
