Yes mate. Here it is. Unless Overclockers have a pre built you think would be a better option and thank you
- System: Intel Core i5-9400F Processor (6 Cores, 2.90GHz Base, 4.10GHz Turbo, 9MB Cache) | H310 Chipset Motherboard | 8GB 2400MHz DDR4 RAM | 240GB SATA-III SSD | 1TB 7200RPM SATA-III HDD
- Graphics: Nvidia GeForce GTX 1660Ti 6GB Graphics Card | HDMI 2.0b, DVI-D, Displayport v1.4 | 400W 80 Plus Rated Power Supply
- Connectivity: 4x USB 3.1 Gen 1 | 2x USB 2.0 | 1x PS/2 KB or Mouse Port | 1x RJ45 Network Ethernet 10/100/1000 | 300Mbps 802.11n Wifi | 5.1-Channel High Definition Audio
- Case & Cooling: Cooler Master Masterbox MB520 Mid Tower Case | Intel Standard Cooler | 4x RGB LED Fans, RFID Remote
Seems alright, terrible PSU and low amount of RAM. How much is 8GB extra costing you? Also the 240GB SSD + 1TB HDD combo isn't ideal when 1TB SSD's are only £75 these days..
I'll see what I can find for you, it is hard however this time of year. DO you really not have time to build it before Christmas then just pop it in the box?
My basket at Overclockers UK:
- 1 x AOC Gaming 24G2U 24" 1920x1080 IPS 144Hz 1ms FreeSync Widescreen LED Gaming Monitor= £179.99
- 1 x AOC Gaming 27G2U 27" 1920x1080 IPS 144Hz 1ms FreeSync Widescreen LED Gaming Monitor= £214.99
- 1 x OcUK Gaming Enigma Essential - Ryzen 5 2600, GeForce GTX 1660 Super = £683.96
- Solid State Drive:TeamGroup 500GB Vulcan SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
- Memory:Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30
- Graphics Card:*Build Stock* Gigabyte GeForce GTX 1660Ti OC 6144MB GDDR6 PCI-Express Graphics Card
- Operating System:Unwanted
- Security Software:Unwanted
- Case:Kolink Citadel Micro-ATX Case - Black
- Processor:AMD Ryzen 5 3600 Six Core/Twelve Thread - Tray
Two monitor recommendations also included which'd be a good match for what you want. I prefer 1920x1080 at 24" size but some don't mind the loss in text sharpness in exchange for larger 27".
You'd need to install Windows 10 on your own or fork out an extra £110.
Thanks mate. Installing Windows has been a concern of mine but there's plenty of How to's out there isn't there?
