Spec me a CCTV System
9 Mar 2003
Decent 'cloud' (e.g. Nest, Ring etc.) cameras are cheaper to set up because you don't need local storage to record back to but typically have ongoing subscription costs.
Camera's built around local storage are more expensive due to the extra hardware needed but don't have ongoing running costs.
That's your choice.
Caporegime
18 Sep 2009
Dormanstown.
buy cheap and buy twice.
if you want a cheap setup just get 5 yi cameras and stick them in every window with an SD card in each. total cost £150 and it does everything through wifi too.
I don't need 5 cameras.
Pretty sure one will cover what we actually require, if that set up proves sufficient I'd then get a second for the back.
The problem would be doing cabling for the one at the back to the NVR for example. It'd be nigh on impossible for us to have it in anyway I'd be comfortable with.
11 Apr 2004
Caporegime
18 Sep 2009
Dormanstown.
That's your choice.
I'd have thought they'd have an SD card slot or something though, rather than needing a full back end.
30 Jul 2007
Lincolnshire
I'm not exactly made of money lol.
The Hive outdoor camera seemed great for what it is.
It's easy to plug up and it "just works" for ~£160.
Although it lacks any local/LAN storage and only seems to upload to cloud, so if we were to set it to 24/7 record it'd be absolutely smashing my upload?
I just want something as simple as that but local storage that can be accessed over WAN.
If you can drill a wire e.g. Ethernet and get a PoE adapter, I can recommend the Reolink PoE cameras. I have 2 I installed a few months ago and the quality is fantastic.
I have them connected to my server recording locally. But you can just pop an SD card in and they record straight to that (no NVR needed). The app works great and you can playback through the app if you have the SD card in too.
I was very surprised for the price :) They do have a wireless equivalent but I haven’t used it so can’t comment.
https://www.amazon.co.uk/dp/B07C75C47B/ref=cm_sw_r_cp_api_i_TbU7Db11ZPRVG
JRJ
JRJ
21 Oct 2010
Sparx just out of curiosity did you fit these yourself? did you drill the cable hole and mount the camera directly over it so no cables are visible, all the pictures I see of the 410 have the cable exiting the side of the mount.
17 Apr 2007
London
So my Ring Spotlight cameras that I ordered a few weeks ago were delivered yesterday. I have decided to use the ring cameras for the time being until Hikvision release a black model of their ColorVu cameras.
I wanted to get everyone's opinion about where I should install the Ring Spotlight camera to cover the front door. I have a porch, with patio doors, so could either install the camera on the left of door, above the door etc. Ring also recommends installing the camera 3 meters high?
Any assistance is appreciated, thanks in advance.
30 Jul 2007
Lincolnshire
I used a cheap junction box from B&Q on the wall first, then mounted the camera onto it. Works perfectly.
The cables together are quite thick, so you’d need a rather large hole, or just use a junction box and let the cables sit inside it like I have, no cables visible. :)
25 Oct 2014
If I was to pick up the colorvu 4mp camera would a 1tb drive be enough? Wouldn't need months of footage, just more like 2 weeks at a time ideally
A typical 30 min recording is 3.3GB on the 4mp colorvu. If you have it set to motion control the file sizes will be much smaller.
11 Feb 2010
England
Held off pulling the trigger on a colorvu setup in the end as the cost of Christmas started adding up!
Is is worth looking at a cheaper wireless option such as the blink xt2? Appreciate quality between the two will be vast but would just be happy for the motion detection alert and the deterrent factor.
Still leaning towards the colorvu but the price and ease of setup is appealing. Anyone recommend a wireless camera?
17 Apr 2007
London
I am still tempted by the ColorVu...I keep going back and forwards between Hikvision and Ring Cameras. I think I have again settled on the ColorVu cameras. From a wireless perspective, I believe there’s lots to choose from (Nest, Arlo, Ring) etc...
9 Mar 2003
Blink are ‘ok’ and very flexible because they are completely wireless but you need to understand how they measure their battery life. For starts they use very expensive lithium non rechargeable batteries to get the maximum capacity.
The two year claim is based upon an average use per day of 8 seconds of Live View, 60 seconds of motion-activated recording and 6 seconds of two-way audio.
Or
Standard use is defined as 8,000 five-second events per year (or 40,000 total seconds of video recording, to include Live View usage).
You also have to use the standard setting of 5 second clips to get this, it’s really not a lot in the grand scheme of things. The video quality also isn’t as good as a nest/ring or a dedicated setup.
The Nests and Rings of this word are more expensive and have a subscription attached but have better quality and recording options. Cost of these are pretty high when you look at the total cost of ownership.
A locally recording setup will likely have the highest upfront but will have the lowest total cost of ownership and the highest quality but are more difficult to set up. You can also better match the camera to the location it’s being placed in.
30 Mar 2007
Essex
5 camera setup with Blink XT2 here
Have 2 running of a solar panel charger and the other three are cabled into the garage, Zero issues after a months use and set on high quality video for all 5 cameras . We’ll see how the battery use wears up into the New Years for the Solars .
£400 all in in a happy bunny so far .
11 Feb 2010
England
@Psycho Sonny now swaying towards a hikvision bullet darkfighter cam. Really only after a single camera setup to cover the rear.
The hikvision cameras seem to come with an in built-sd slot. I'm guessing this is a backup and can't use without an nvr?
Caporegime
21 Jun 2006
i use dahua system. so i'm not sure i think the hikvision colorvu are the best cameras.
if you are only using a single camera. i would be tempted to just use a cheap smart cam. NVR and POE and cabling is a lot of hassle for 1 camera. the NVR would be wasted on a single cam.
why not get a ring security light camera? it probably has subscription costs though. if i was going to the effort of buying an NVR I would get at least 4 cameras. 2 front and 2 back.
