GTX 580 in SLI Vs Xbox S - advice needed
11 Dec 2019
Hi guys,
I have an old PC which has been unused for a while, and I'd just like to know how this will hold up for modern games in 1080p.
The PC's specs are:
- I7 2600k (may be 2700k but I think it's 2600k)
- Two GTX 580 MSI lightnings with 3GB VRAM running in SLI
- 16GB DDR3 RAM
IIRC the CPU was overclocked to 4Ghz
How would this compare to the Xbox in running Forza Horizon 4?
How would it compare generally speaking for modern games now? The PC was built in 2011 and I worry about how it will hold up.
I don't want to spend any more money on hardware though so I'd just like to get people's thoughts on how it compares.
Any help would be much appreciated. Cheers!
OP
11 Dec 2019
Some people on here are still rocking that i7 processor... With its quad core and 8 threads it will still do a great job in games, if you don't mind knocking a few settings down.. If you was to change anything I'd recommend GPU first
Do you know how it'd perform?
I have an Xbox S that I can buy for £80, so it's a no brainer vs a hardware upgrade to the PC which would cost several hundred.
The Xbox S isn't as powerful as the X, but I only have a 1080p monitor so I'm not sure what to do really, to be honest.
27 Mar 2016
Bristolian living in Swindon
If you have around £80 to spend, I've seen a few RX570 going for around that price, that would sort your PC out
10 Sep 2009
Gloucestershire
You should be able to get £150 or more for the bits on Ebay. Just sold two i5 3xxx processors for £30 quid each and they were priced to sell quickly (hmm actually both went in a hour!). Expecting to get ~£40 for a HD5870.
i5-3570K + HD5870 could still play games like Fornite at 1080p with 50 fps so still capable but the 2GB VRAM on the HD5870 was a big limiter.
I'd sell the bits and put it towards a console or more modern CPU/GPU/mobo/RAM combo or as suggested just the 2 x GTX 580s to start with and try a more recent single GPU.
Average Ebay Price Checker suggests possibly £50 per GTX 580.
OP
11 Dec 2019
As above not sure if you need Win10 but there's a trial for Horizon 4.
I have an 1155 socket on the motherboard, would I have to buy a new motherboard too?
Depressing this really. When this pc was built in 2011 in was worth almost £1500. Now it's no more useful than an £80 Xbox, surely that can't be right?
OP
11 Dec 2019
Oh god, that didn't even occur to me.
The PC has windows 7. So I'm going to have to spend on a new operating system I don't need or want just to be able to play it?
I can't get my head around how a system that was aimed at being future proof and cost so much at the time, can be less useful than a sub £100 Xbox now. I thought it'd be alright
14 Nov 2012
Close to Swindon, but not Swindon
It all depends on what games you're playing. There are modern titles that will max out the 4c/4t CPUs causing stuttering ingame (my brother had this issue due to 100% CPU usage). I would be looking at a GPU upgrade and then if you have performance issues, upgrading the CPU/Mobo/RAM.
Also, you don't need to spend lots on a Win 10 upgrade. You can still get Win 10 for free or pay £2-3 for a key off the bay.
Don
19 May 2012
Spalding, Lincolnshire
Eh? Try playing Forza Horizon 4 on a ~2011 vintage XBox... oh wait you can't.
Why don't you try it?
Massively underrated comment.
It will probably work, given that the minimum graphics card recommendation for Horizon 4 include GTX650ti/GT740/R7 250x, which are all much less powerful cards than a GTX580, especially if you do indeed have the 3GB Models.
Indeed a quick look suggests that the GTX580 holds up reasonably well against newer budget cards:
https://www.techspot.com/article/1565-geforce-gtx-580-eight-years-later/
Forza Horizon 4 PC minimum requirements
  • OS: Windows 10 version 15063.0 or higher
  • DirectX: DirectX 12 API
  • Memory: 8GB
  • VRAM: 2GB
  • Processor: Intel i3-4170 @ 3.7Ghz or Intel i5 750 @ 2.67Ghz
  • Graphics card: Nvidia GTX 650 Ti or Nvidia GT 740 or AMD R7 250x
10 Sep 2009
Gloucestershire
i7 2600K is 2nd gen and we are on the 10th gen so there's a lot of hardware out there now despite the CPU still being very capable of many tasks. My brothers i5-3570K system was still playing many games quite happily but lack of RAM and the HD5870 with only 2GB VRAM. Then it died!
So now he has my i7-5280K + GTX 980 Ti and that's everything fine at 2560 x 1080. I'm still on another i7-5820K @ 4GHz + 1080 Ti and that doesn't suffer any stutter on modern games probably due being one of the first affordable 6 core processors.
Check this article out though and a good match is a GTX 1070 or RX580 and even when tested with a 1080 Ti it was still 60fps+ in just about all games which compares very well with consoles.
https://www.techspot.com/review/1546-intel-2nd-gen-core-i7-vs-8th-gen/
OP
11 Dec 2019
How would you get it for free mate? I've never installed an operating system over an existing one, how easy is it?
Have you misunderstood mate?
On what planet is a pc worth well north of £1k equivalent to an Xbox of the same gen?
My point was that you would expect an 8 year old high end over £1k pc to stand it's ground vs an entry level present day Xbox you can get for sub £100.
Otherwise what's the point of spending all that money? Where's the investment?
Thanks for the link.
So I may he alright, but I'll have to download windows 10 for definite it seems?
Don
19 May 2012
Not at all
They were both designed for the games that were around in 2011? :)
No I wouldn't - 8 year old tech is 8 years old, things have moved on in the PC world. If you want a fixed platform for gaming that only needs updating every 5 years or so then you absolutely should buy a console.
Because when you invested in a high end PC in 2011, the graphics capability was hugely better than the equivalent console at the time (XBox 360), You would have been playing at 1080P Max settings, vs a console that managed at best 720P.
The point of spending "all that money" is to get a better experience now - longevity isn't guaranteed. If all you want is console quality graphics, then there was no need to spend all that money - it could have been done at the time for much less.
