Don
- 20 Oct 2002
- Oxfordshire / Bucks
you need a double garage Gibbo
it just fits !
it just fits !
it just fits !you need a double garage Gibboit just fits !
. Do you put the windows down to make access easier. I remember when I had my 911 in the garage for the one and only time and it was tight, not helped by doors being long due to being 3 door.I bet you have to breath in when getting in/out in that garage. Do you put the windows down to make access easier. I remember when I had my 911 in the garage for the one and only time and it was tight, not helped by doors being long due to being 3 door.
Pretty much the same with all garages in most homes. Built for cars from the 1970's. When the missus goes back after maternity I am looking to get our garage widened and lengthened. At the moment I rely on foam and carpet to make sure i do not damage the doors! Even still it keeps the car nice and warm during the winter months!
This is very much true and one reason we chose the house we did when we moved last year and the garage is almost 6m wide with two full width single doors. It's wide enough to get two cars in comfortably (and even some room for storage too!).seems a lot of modern houses with garages are intended for storage only and not a car it seems as even some modern built houses we looked at the garages were too small.![]()
Absolutely top quality, very robust (you can jack directly off it), strong enough to drive a truck over it, goes down super quick: with the completely clear double garage I did the whole lot, start to finish, including cuts along all the walls which took longer than the bulk of the floor in about 8 hours. That's probably 2 hours to put the main lot down, and 6 hours faffing around the outsides, measuring and cutting with a hand saw. If you had a tile chopper and an extra pair of hands you could probably reduce that to 4 hours total start to finish I'd think.@Havana_UK care to share your feedback on this swisstrax flooring? I've been looking at options, this looks interesting?
I've got something similar, and I echo above, it's the trimming or 2 walls that takes the time, and rearranging the contents of the garage to get access.@naefeart
If you want a cheaper option I recently installed Mototile interlocking tiles in my ~6.5 x 3.5m garage for just over £500. Would definitely recommend them
Garage floor covering recommendations
We've now got the wife's 2nd car in there, so things are a bit more cramped, but I've also got a lot more storage space in there since this was taken:
Despite this, most of the people around where we live now don't put a car in the garage but everyone parks on the driveways instead.
If you want some flooring for the garage I'd recommend Swisstrax Ribtrax. Would cost about ~£600 for that size garage I'd think, but it's worth every penny - really top quality stuff.
Nice one mate!! @Gibbo I see you also found a good spot for that wreath!!!![]()
You need an excuse to drive a Ferrari a couple of hundred miles?!![]()
