Go for the AMD kit - 1151 is a dead socket; you might want to consider the B550 when it comes out shortly, but the B450 is still very good
im looking to upgrade my pc and was wondering if i should go with a b450 with ryzen 5 3600 + 16gb ddr4 3000mhz or intel and a 1151 mobo and 16gb DDR4 3000mhz?
Well on the AMD front I'd get some faster RAM. 3600Mhz if you can or 3200Mhz on a decent B-die kit so you can OC it to 3600Mhz. I'd go AMD as there will still be another Generation of CPU's that'll go in that board.
Think it was GN who stated at CES that B550 wouldn't be out until at least third quarter?
+1.
Zen2 TBH is much better at attaining higher RAM MHz on even other RAM IC besides Samsung B die. Micron E-die based dimms I'd say are a better buy as can usually be had for less and can reach 3600MHz with minimal fuss. Yeah Samsung B die still may allow tighter timings, but the return is so little for outlay that your better off using that spend on a better GPU, etc IMO.
If the security updates are installed for the intel cpu, this is not the case though. Whether or not an average user decides to patch the vunerabilities is upto them, ofc.The 9600K is higher clocked than the Ryzen 3600/X so in most games it is a little faster, really not by much, under 10% on a 2080TI at 1080P.
