Poll: *** The All New Windows AV Thread - Keep All AV Questions in Here ***
What AV do you use?
  • Total voters
    801
18 Oct 2002
Northants
I honestly don't think its needed anymore if you're not stupid, I just run defender and have never had a single problem, out of curiosity I'll run a scan every 6 months and nothing.
18 Oct 2002
Livingston
Can someone recommend me either the best free or best low cost licence AV solution please?
I forgot to mention that this isn't for me, but for a family friend who is just your typical everyday user. Just need something that'll run automatically in the background ideally.
22 Sep 2006
Depends what you need, some third party AVs have lighter resources then Defender ie less ram, cpu usage , better virus detection etc, personally I use Bitdefender Free version which IMHO is better then Defender.
22 Sep 2006
I use Bitdefender Free version which is lighter on resources then Defender ,no advertising and has great detection rate ( one of the best).
Gamer here too :)
Capodecina
30 Jul 2006
No, they do a free version which has no time limit.
I can't say I am impressed by BitDefender; I tried the 30-day evaluation and so far as I can see, there is little opportunity to determine what should happen when a "suspect" file is detected and I can see no report on the actions taken by the software. I am sure that it is all there, just not obvious.
I think that like the Russian Kaspersky, I will forget the Romanian BitDefender.
