Wiring a hot water pump
Permabanned
8 Feb 2004
Hi
Can I wire a hot water pump such as a Grundfos 15/50 direct from a mains socket plug by simply connecting up the live neutral and earth wires to the corresponding terminals? I understand I will require a 3A fuse and need to follow the manual in relation to using 1 mm2 cores. Will this work?
Thanks
Yes you can wire a 15/50 with 3 core heatproof flex to a 3 pin 3A fused plug. My question is why would you want to? And are you aware its a heating circulator?
Mick
Mick
Hi, thanks for the reply. I want to have the water circulating through my heating pipework periodically while I attempt to clean out my boilermate thermal store with a few fill/drain cycles.
Gledhill Boilermates have 3 pumps (the ones I've seen) what are you trying to do and how? If you dont mind me asking ;)
My idea is to top feed and drain the system at the same time until the water from the drain runs clear.
I will have the heating circulation pump running at the same time to get fresh water in to the heating loop and provide some agitation and mixing of old and new water.
draining thermal store whilst running heating pump and draining via a drain off is a very bad idea, you are going to drag so much **** through your pipework its going to settle in places you don't want it afterwards
But the water in the thermal store circulates through the heating pipework and radiators during normal operation. I don't see the difference.
Hose pipe from mains to 1 drainoff `male chicken`
hose to lowest other drainoff `male chicken` to outside drain
Turn off all rads bar one,last in line /top of house
Turn on water ,watch output till it runs clear
Turn on next rad in line,then turn off previous rad.Rinse and repeat till all done
This is what i have seen plumbers do on many occasions
Really?
I would have thought that that method would clear ALL pipework?
Is it not like using a `PowerFlush`?
I'd imagine you need to take each radiator off the wall and clean them out with a hose - for example, turn each radiator upside down, fill, agitate, empty and repeat until water runs clear. Then clean the pipes with a proper power flush with magnetic filter before reattaching the radiators. Finally add inhibitor. I think it's best to add system cleaner into a running system for a week to get the best results.
Really?
No, nothing like, and your applying mains pressure to a heating circuit. Those components are not rated for mains pressure. If you fill at one point and empty at another your only flushing whatever leg of pipe is in between. A power flush machine washes an individual circuit including radiators, using chemicals and agitation. This is done through every radiator circuit until all clean. :)
