Upgrade advice please
13 Jan 2015
Hi all,
I would appreciate your advice on upgrading my PC. I've had advice from here before on upgrading my graphics card, SSD and PSU and the recommendations have always been spot on.
I'm not really sure where to go next to get the most out of my PC. I was thinking a new processor or maybe new motherboard and RAM? Perhaps both are needed, as the computer is getting on a bit, some of the parts are from the original build in 2012. My budget is very flexible, I was thinking <£600, but happy to spend more if worth it.
My build:
Processor (CPU) Intel® Core™i5-2500k Quad Core (3.30GHz, 6MB Cache) + HD Graphics
Motherboard ASUS® P8Z77-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
Memory (RAM) 8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
SSD: Samsung 860 EVO 500 GB SATA 2.5" Internal SSD
Backup HDD: Seagate 2 TB BarraCuda 3.5 Inch Internal Hard Drive 7200 RPM, 256 MB Cache, SATA 6 Gb/s (just purchased and not installed yet after my old HDD started to fail)
GeForce GTX 970 TURBO OC 4096MB GDDR5 PCI-Express Graphics Card
DVD/BLU-RAY Drive 12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW
Power Supply Superflower Leadex Gold 550W "80 Plus" Power Supply
Processor Cooling INTEL SOCKET LGA1155 STANDARD CPU COOLER
Sound Card ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO
1440p Monitor
Man of Honour
26 May 2012
carry over
new core:
My basket at Overclockers UK:
Total: £634.06 (includes shipping: £11.10)​
OP
13 Jan 2015
thanks for your reply, I really appreciate it! If I was going to change all of the above, I would probably increase my budget to 800-1000 to make it last a bit longer. Would you change anything from the above basket if so?
21 Nov 2019
Take a look at the Rx5700XT as well as it offers 2070 super performance for about £100 less. Mine (Sapphire pulse variant) has been treating me great and I'm about to upgrade to 1440p to fully utilise it
Man of Honour
26 May 2012
Sabrent Rocket Q 1TB NVMe PCIe is?
it's Q for QLC nand.
the original sabrent rocket uses TLC nand = better nand endurance and sustained speeds
QLC nand slows to a crawl once the SLC cache is used up
(though it doesn't matter too much for 99% of real world uses)
OP
13 Jan 2015
Thanks for your advice everyone, I have purchased the basket suggested by tamzzy and have cancelled my order for a replacement HDD. I will get a TLC Sabrent Rocket instead
