AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
6 Feb 2019
I've had the same problem with 3 different soundcards. Crackling and eventual hard reboot only occurs with RAM set at 3800/1900IF and 3733/1866IF. When I set RAM to 3600/1800IF the crackling goes away. I tried many different SOC & VDDG voltages. Strangely the RAM will pass ram test for hours without issue.
For the time being I have left it at 3600/1800IF because at 4K gaming the difference was frankly margin of error.
Focus on lowering the timings, if you can get it to 3600 CL14 with 1800IF, the gaming performance will be just as good as you had with 3800, if not better
26 Sep 2017
In the Masonic Temple
But I'm on 1900 3800 cl14 now 62.5ns, hurts me to go down to 3600
All is fast and stable apart from the sound issues, cinebench good, 3dmark good, stress test good, memtest for 12 hours all good
18 May 2010
London
Thanks. Yea seen it's been out for a while now but dont really want to be running a beta version on y system.
What the heck are Asus playing at. It's been 5 months since this Agesa first started to be released and they still haven't managed to release it across all their lineup...
It feels bad to spend £180 on an x570 mobo just for an up to date bios... but it's tempting. :o
5 Nov 2010
Hertfordshire
I moved to Gigabyte in the end. X370 is not something ASUS are willing to support properly any more.
15 Oct 2019
Uk
Or grab a b450 max and save yourself 90 quid.
25 Oct 2013
Kent
14,16,14,14 32,48
Just did a dirty auto everything then plugged 3800Mhz 1:1 at 14-16-14-14-32 and I am getting 65ns.
With a quick tweak a week or so about I got down to 64ns but I am not sure what I am doing wrong to not get the numbers down.
EDIT: Even 14-14-14-14-32 is not yielding less than 65ns.
26 Sep 2017
The sub timings are where the tweaking begins, have you used the ryzen ram calculator?
23 May 2016
Lurking over a keyboard
Used the RAM cal and I am down to 63.6Ns but oddly, 16-16-16-32 and 14-16-14-32 have the same 63ns.
I do wonder if using a 3600x over a faster 3800x+ would make a difference.
The R7 3700X I had was no better than R5 3600 when compared at 3733MHz, the R7 couldn't do 3800MHz.
2 CCD CPUs bench better in AIDA64 from my experience, even when you put aside the write difference, this is R5 3600 PBO+150MHz 3800C16 Samsung B die vs R9 Stock 3800C16 Samsung B die vs R9 Stock 3800C16 Micron E.
20 Aug 2019
SW Florida
Coming from a 3770k to this new architecture, I have had to change my thinking on how to identify instability. Zen 2 seems to be really good at "working around" instability, so BSOD's are seldom how instability shows up. I'm currently working on getting 2 sticks to run at 3800. The dram calc settings *almost* worked 16-16-16 32, but gear down mode renders more latency and worse Shadow of the tombraider benchmarks than 2T. When I see results like this, I assume I have a stability issue and make adjustments.
I left the 2T in place and decided to tighten CL by one (15-16-16 32). Latency came in @63.0ns, and it's running memtest now.
Basically, if better settings yield worse results, assume stability issues. (Run multiple tests to make sure worse results weren't just a fluke)
18 May 2010
London
Tomahawk?
I read on the product page that it supports memory speeds up to 4133(OC) MHz and yet online reviews say that it's weak point is the memory overclocking.
Why is this board so highly rated on these forums?
Is the Gigabyte B450 AORUS PRO any good. Aesthetically speaking it looks better. :p
Does the Max support PCI-E 4?
15 Oct 2019
Uk
Tomahawk?
I have my ram running at 3800/16 on the tomahawk and with tighter timings than my brother managed with his x570 taichi same ram so I wouldn't say ram oc is a weak point.
It's well built with a good vrm and excellent heatsink so dropping in 16 cores in a few years isn't a problem.
Do you need pcie 4? GPUs dont as the top ones only just max out pcie2 and unless your moving a lot of data around then pcie4nvme isn't worth it either.
No real reason to pay more unless you have an unlimited budget or need the extra features as that 90 quid saving could go into a CPU or gpu upgrade and give more bang for your buck.
