That looks stunning/very exciting!
Some of the pictures I've seen are astonishing! Il need to brush up on my photography skills!
Whatever you do, don't go up Ben Nevis is blizzard conditions in trainers!. . . As a reminder this is for my trip to kazbek in July
Who is organising the trip? They should give informed advice.
If you are anywhere near Keswic - visit George Fisher, you could also try the Paramo shop and even Cotswolds.
Realistically, unless you're caught out in some miserable weather, it probably won't be that cold and most likely if the forecast is rubbish, you won't be going for the summit. You'll be surprised how little clothing you actually need, especially when you're moving. I find it's generally worth suffering a bit in the cold on an alpine start so you aren't cooking when the sun comes up on the glacier and having to stop and delayer, wasting time. It's worth getting your clothing system nailed on before you go if you can to minimise faff as delayering when you're roped up is a pain.
Down trousers will probably be overkill. I've climbed up to around 4500m and have only needed softshell trousers. In places like Norway where it was about -25C, I used powerstretch leggings and windstopper softshell trousers. If you're doing the Normal Route, there aren't any technical sections so you won't be stood around belaying getting cold. Try and keep kit to essentials too as little bits here and there soon add up and everything is much harder at altitude!
So couple of quick questions ( two of probably many ) for you more experienced people.
I have sorted out a top and bottom base layer a down jacket rated for upto -30c. And waterproof top and bottoms
What would I ideally want to take
#1 as a mid layer for the upper ( I'm guessing a warmer and cooler option is a good idea?) but don't want to over pack.
#2 for trousers should I be looking for something in particular such as down fill.
Sure il have more questions to come
Jottnar elvar (enough insulation when combined with below)
How come you have b3 boots? Are you ice climbing otherwise b2 would have been sufficient and better for walking since they will be slightly less stiff
I tend to have a a 4 layer upper body system rather than a 3 that I swap out.
Henley Hansen striped crew baselayer
Rab shadow hoody (breathable when active)
Rab fuse ii (waterproof and windproof to knock the bite off
If its raining when strenuous I'll wear hoody and fuse ii, if its none strenuous I'll wear full 4 or take away the hoody. If I'm really going at it I'll probably just go in the fuse ii.
Not raining I'll take away the fuse ii.
I love my shadow hoody though it's so breathable. Cold if stood still but that's where the backup insulation comes in which is just enough. If winter conditions some people get an additional belay jacket to stick over the top of everything to keep warm but I've never had a problem with 4 layers though sometimes if really cold I'll add a t-shirt.
The trick is not to sweat so just wip a layer off as and when. Taking a light to mid insulation layer off is far easier than swapping it out for another and if you get a good waterproof shell it will be windproof enough I've found for UK.
I've never had problems with legs really I either use henley base layer legs with stretch trousers or insulated soft shells and overtrousers as backup.
How do you rate that? I've got some other Jottnar kit and the quality is great and as my old Atom LT is getting a few too many holes in it now I'm tempted to treat myself to one of those as a replacement.
Yeh, that's what I've found, there's hardly ever any discount on them whereas other brands you can snap up cheap in end of season sales. I've got one of their waterproofs which is fantastic and I managed to get a discount code on that which brought it down to around the same price as ME jacket I wanted otherwise I'd have gone for the ME. Annoyingly the discount code needed to be used on two items though so I had to treat myself to a new hat at the same time.
The Atom has been perfect for me, but I've got an old version with no zip lock on the main zip. It seems like such a minor thing but it always works it's way down when you don't want it to. I'd buy another Atom but I'd rather support a British company, although the Atoms usually crop up in sales for a decent price. Cheers for the Fatmap tip, looks like they offer discount at quite a few places so might be worth considering.
so who is the good patagonia supplier in the UK ... tbo most of their stuff is good -
I need some new patagonia capilene base layer tops - have 3 I've used in rotation for running/walking/cycling/(climbing/skking) base layers, 5days a week.
last addition to the family was from chamonix patagonia shop ... gear and climbing mecca ... I never complain about going shopping there.
salopette type high waterproof overtrousers(mountain range), with braces, and zips are useful if you need to wear a harness, and put on without removing boots .so have invested into a nice pair of b3 boots
I'm reluctantly going to have to powerstretch I like patagonia long johns with a polartec trouser, but don't seem to have many 200 weight ones anymore.In places like Norway where it was about -25C, I used powerstretch leggings and windstopper softshell trousers.
yes .. I've only ever considered as breathable top outer level ....i'd just be using layering with a decent goretex jacket to wind break and rain, and not down jacket. But, depends on predicted amount of rain also.
so that's where I've put most of the investmentJottnar elvar (enough insulation when combined with below)
A nice gesture by four very lucky people but there must surely be some way of making people more aware of the dangers in hills and mountains, even in fair weather.Four men rescued from Ben Nevis in high winds and blizzard conditions have apologised to, and thanked, their rescuers.
Lochaber Mountain Rescue Team and Inverness Coastguard helicopter went to the aid of the tourists, who were not equipped for winter hillwalking. (LINK)
I've never been up Ben Nevis, so this might already be there, but it just needs a big sign at the bottom of the tourist path over the path itself warning people that it's dangerous to go without the correct equipment for the time of year, much like what you get in ski resorts for gated terrain.A nice gesture by four very lucky people but there must surely be some way of making people more aware of the dangers in hills and mountains, even in fair weather.
I have been up Ben Nevis a few times (as a hill-walker, not a climber) and I have a vague feeling that there was a prominently displayed poster based on an article in a newspaper about some foolish people who went up in T-shirts and trainers and had to be rescued - may not have been there or may no longer be there?I've never been up Ben Nevis, so this might already be there, but it just needs a big sign at the bottom of the tourist path over the path itself warning people that it's dangerous to go without the correct equipment for the time of year, much like what you get in ski resorts for gated terrain.
They can list that on the sign. It's a simple solution, at the moment (as far as I'm aware) there's nothing at all to warn people that though at sea level the weather might be relatively pleasant, another 4000 feet up it's a different story.That only works if people know what the correct equipment is.
An average person with no hillwalking experience thinking about going up Ben Nevis in winter might consider the correct equipment to be warm layers of insulation, waterproofs, gloves, etc and not think about crampons, ice axes, goggles. Also, simply having the correct equipment isn't always enough - many people have got lost in the hills whilst carrying a map + compass because they didn't know how to use it properly.
It might be the case that more education than can fit on a sign is required. I don't know what the solution to that would be though?
