Theres some on ebay for 185. Think its legit ?
I'd be surprised. Maybe a heavily damaged but working one?
185 is gone but there's a few like this :I'd be surprised. Maybe a heavily damaged but working one?
https://www.ebay.co.uk/itm/Apple-Wa...710602&hash=item42131bd7d7:g:y84AAOSwsvVeTTwD
Does anyone have any thoughts on the above? I now have the AirPods and Iphone and first run with them today went really well. I have also seem a series 3 Apple Watch for £185. Does that represent good value for money for my needs and what would I be missing out by getting this above a series 4 or 5?
I'd avoid the 3, plus i'm sure you can get them used for around £100, you could always get one used and see if you like it enough to spend more, should get most of your cash back.
I'd say the 4 was a decent step up from the 3, the 5 from the 4 less so.
The Apple is good, especially if you're in the ecosystem. Note though that you need to use Apple Music for standalone music on the Apple watch, whereas some Garmin watches will allow Spotify playlists to be synced.
I suppose it depends on budget too, you mentioned that Garmin at £150, any idea which one that is as there's a big range.
The main question you want to ask yourself is do you want a fitness watch thats a bit smart, or a smart watch which will do most of the fitness side.
I had a Series 5 Apple watch and sold it for a Garmin Fenix 6, however that's at the top end of the range and i only really made the change because of the extended battery life for some long 50 mile runs i'm working towards. Otherwise the Apple watch was fine for general running around and even for marathons.
If i was in your shoes, i'd look for a used/refurbed Series 4. Should get it for around the £150-£200 mark. Give it a few months and see how you get on with it. If you love it then i'd hold off till September when the Series 6 is out and i would expect that to be a bigger jump than the 5 would be.
I'd either stick a wanted post on here/avforums where there's a decent community, otherwise Ebay is your best bet, can usually pick up one when ebay push their 10/20% off selected seller offers.
I think the problem is that the 5 wasn't a big enough jump, so the S4 owners aren't upgrading which limits their availability, i think this shows by the discounts which often pop up on the S5
The always on display on the series 5 is a game changer, completely changes the watch. Don't let anyone tell you otherwise!Does anyone have any thoughts on the above? I now have the AirPods and Iphone and first run with them today went really well. I have also seem a series 3 Apple Watch for £185. Does that represent good value for money for my needs and what would I be missing out by getting this above a series 4 or 5?
See if anything in here tickles your fancy.Anyone here able to recommend any 3rd party straps? Looking for a couple basic ones, just plain black and a plain grey one.
