However, having carefully washed and dried your hands you then have to grab the germ infested door handle and pull it to get out! What genius thinks up and/or specifies these brilliant hygiene schemes?
You too have kinda missed the point.If you have a power cut, the door must fail 'safe' ie open.
So there you are with your crackers around your ankles....
That would be a VERY good idea, they have them all over the place in hospitals and in many GP Surgery waiting areas. . .
What they should do is have a bottle of the hand steriliser outside the loo [IN A PROMINENT POSITION] so people can rinse their hands in it after they have left.
That swings both waysFrom what I recall, doors open inwards to avoid a door opening in to a corridor or place with high footfall, for obvious reasons.
Those Dyson hand driers are riddled with bacteria.
Have the foot based handles you can open with your shoe, simple, cheap....
They find traces of poo everywhere.I'm not sure if they are true, but I've heard several gross stories at one customer site, one included the Dyson hand drier.
I have my doubts about this, but I heard someone removed the cover and put a poo in there, so it would be blowing air over the poo to dry your hands
Another story I do believe from the same place is that traces of urine were found in the water cooler, grim.
It's not actually anything to do with hygiene it's to do with cost, the "automatic" ones are simply cheaper (I enquired into the rationale a while ago as the "automatic" ones are harder for the disabled to use).However, having carefully washed and dried your hands you then have to grab the germ infested door handle and pull it to get out! What genius thinks up and/or specifies these brilliant hygiene schemes?
