A few bent pins on the 3700x
2 Jan 2012
Something strange has happened. I got a refund for the seller but they haven't requested the part back...
I was surprised so queried it with ebay. They said if the seller doesn't get it touch within a week, I should keep/dispose of the part.
Whole thing is gettering weirder.
That's weird... Maybe you can try fix it anyway :D
22 Sep 2009
Probably an active forum member following this thread.. :D :p
Man of Honour
22 Jun 2006
Do they sell many computer parts? I think some sellers just buy lots of returned stuff at auction and maybe they took a quick peek in the box and didn't even realise it was broken.
OP
8 Aug 2004
Sussex
Only one memory slot works. :(
So, with only mild persuasion I got the processor into the socket. No real issues there, any pin that remained slightly out of line was forced straight.
After that very first boot (leading to the screenshot above) I moved the main memory stick to slot A2, and then booted - fine.
Then I added a second to slot B2, and it doesn't POST. The DRAM light on the B450A comes on.
Tried both sticks in slot A2 - gets to the BIOS fine. Tried to reseat with the two stick configuration - no dice.
At this point i don't know what to do.
I could pick up a single stick of HyperX FURY 16GB (HX432C16FB3/16) but the graphs that Gerardfraser produced in another thread (https://forums.overclockers.co.uk/t...crificing-dual-channel-memory.18878499/page-2)
All is not lost and single channel is not that bad.I only play PC games and have tested some single channel/dual channel with non tuned memory timings.With tuned memory timings the results would be even better for single channel.
are worrying me.
Tell me what to do!
