So I updated to the latest bios, everything seemed fine at first and booted into windows, loaded the same settings I had previously. Mostly auto with memory profile selected. cinebench score was 1000 lower then normal so went back into the bios and enabled precision boost,and restarted. Got some weird message about the vga not being compatible, restarted and then wouldn't even let me into the bios.. Removed sata drives and it let me into the bios, but not windows won't load.
I can repair the install and get in, the only issue I can see is Asus Suite is going nuts, constant messages about not being able to load... ??
However when I restart windows it again fails to load and I have to go through the repair process again, and again when I get into Windows Asus Suite gives me the same messages.
I can try reinstalling Windows, but why is this happening?
On the plus side cinebench scores are back to normal......
