MITX Board that will take a Ryzen 5 3600 straight out of box.
3 Feb 2004
Its been about 6 years since I've built a PC so am totally out of it as regards to latest PC hardware.
I'm struggling finding an MITX board that'll take a Ryzen 5 3600 without need of updating first. I'll aso probably stick an RX5700 in there as well along with 32GB ram.
Any ideas?
5 Nov 2002
Manchester
I recently got an Asrock B450 ITX which was running a BIOS that supported the 3 series CPUs, it had stickers on the outside of the box stating such. I have the same motherboard I bought last year from memory which did not.
Might be worth checking with retailers directly, imagine other manufacturers may do the same.
17 Apr 2009
Same here with a Gigabyte. Pretty sure it's the case for all new stock across all manufacturers. So unless you get unlucky and get a board that's been knocking around the warehouse for a year, you'll be fine.
If you do find you have a problem, AMD will loan you a CPU so you can do the update.
1 Apr 2014
Aberdeen
Take a look at the DTX form factor, specifically the ASUS ROG Crosshair VIII. It makes use of the overhang of the GPU by stretching the motherboard just a little.
23 Sep 2014
North West
The board is slightly bigger which gives it room for additional features like extra M.2 drives.
No extra M.2 drives. It is still 2 which matches the other Gigabyte and Asus X570 ITX boards. The Asrock only has 1 M.2 though so avoid this one unless you need that Thunderbolt 3.
I struggle to find any benefit of Impact over the boards, and being DTX really restricts case choice.
Just go for either the Gigabyte or Asus Strix X570 ITX.
