Cheap battery charger
26 Oct 2013
Leicester
Hi all
I am after a 'cheap' trickle/battery charger. I have my 2012 mondeo on the drive however I can't drive it obviously due to covid and also it has a DPF vaporiser issue so it's waiting to go to the mechanics.
The dashboard is now flashing up a 'low battery' sign. Either I buy a trickle charger or I just jump start it when I take it to the mechanics. Happy to spend up to £30ish if I can get something suitable? Amazon ebay etc. I can also monitor the battery for charge if necessary as I'm at home.
I don't know whether there are such chargers where you don't have to disconnect the terminals from the battery to the car?
Thanks
hoop up a solar charger/maintainer. if your battery is in good condition the solar ones work very well as long as your not parked in doors or under a tree all the time.
Ring and Sealey have good options too
Ring- RSC404
Sealey - Compact Auto Smart Charger 4A - model number AUTOCHARGE400HF
Both are reputable makes.
Correct, it fits the bill. Have you bought a new battery recently? You'd be paying as much, if not more, and I have 3 cars to keep nice and conditioned during lockdown.
That still doesn't make the CTEK a cheap battery charger. It isn't a cheap battery charger at all.
I used that maypole 4a 12v charger just the other day. Worked perfectly, was quite surprised by the quality for the price.
I bought the aldi one recently. Was only £12.
charged my battery with it twice now but I’ve had to disconnect the battery first (as per the instructions)
Really? I think it's incredibly cheap for what it can do to a battery. I mean, it's not even £70
You are missing the point.
Being good value for what it does doesn't make it a cheap battery charger.
£10 or £15 is a cheap battery charger. £70 isn't - but you already know that.
It's not cheap but I get what you mean, the CTEK saved my battery from almost certain death, the replacement battery would have cost over £130, could a cheaper charger have done it... maybe. However the CTEK has the reputation and I trust it a little more.
This is the main reason I opted for a Ctek over the cheaper alternatives. Plenty of manufactures (Porsche, BMW, Mercedes to name a few) rebadge them and sell them as an approved charger, which gives me a bit more confidence that when I leave it hooked up to my car it's going to do what it's supposed to do.
If I was looking for some longer term storage I'd definitely look at the CTEK MXS 5.0, but for now I hope the £22 jobbie should do it.
Thanks
I have a Ctek C5 and its the dogs, I wouldn't have recommended it based on the op's requirements.
I would have recommended the £12 Aldi jobbie which I also have :)
