Images of items I have purchased (except trainers)
1 Dec 2011
SW3
need to do some research then.
she gives music lessons so mic needs to be good to pick music up
It’s the easiest solution, USB straight into the computer.
You can go for a studio mic but they are XLR connection so you have to go down the route of a DAC etc.
Have a look at the Blue yeti mic, gets great reviews. :)
2 Feb 2011
Been a while since I got any American soda.
14 Jul 2005
Bristol
Do some proper research, there are different types of mics and they suit different applications ( for a quick guide https://www.musicianonamission.com/types-of-microphones/ ), for music you won't want to be using a conventional podcast type mic, they are built to pick up voice better than instruments. I'd suggest spending proper money and not buying the cheaper options of streamer/podcast mics...but do your own research of course.
