- 18 May 2010
Hi,
So its looking like I'm going to be working from home a lot more and if thats the case I cant keep on with my current setup, I'm using my personal 1440P Dell Freesync monitor with my work laptop monitor wedged underneath it so I can access the laptop keyboard and I'm constantly looking down at the laptop monitor and over time its killing my neck to the point where its giving me a lot of agro even after work. My dell monitor is plugged into the laptop HDMI out every morning so I have a make shift dual monitor setup.
After work I pack my laptop away and my desktop which is on the same desk is used for gaming most nights.
I was wondering if anyone else has adjusted to this situation more comfortably than I have and if so what did you do? I was thinking maybe sell my current monitor, buy a dual monitor arm and downgrade unwillingly to dual 1080P gaming monitors, I suppose another benefit of that is I can shrink my PC to a smaller case and take advantage of smaller GPUs in the future giving me more desk space (my desk is tiny)
That would sort the comfort out but then how would I share the monitors between my desktop and laptop, also if I'm currently using the laptops keyboard for work and I then use the laptop via a docking station to the two monitors I'll end up with two keyboards, one for gaming PC and one for work (I cant use my Ducky One2 Mini for work)
Another issue is my current single monitor stand has a removable C clamp as my desk is fixed to the wall with a gap for cable management so I would need to find a dual monitor stand with a removable C clamp and there wasnt much choice when looking for a single stand.
Sorry I feel like I just blurted all of that out, hopefully it makes sense!
Cheers
Cheers
