Pic: Your desk...RIGHT NOW
28 Dec 2017
Beds
Took my PC outside for a clean with some compressed air. Fitted a LL140 fan but realised I have no RGB ports left, and thanks to Corsair's awful design need another 6-way hub to make one extra fan work.
You can bodge one yourself if you want. The 6 way hub just daisy chains the connectors - Corsair has an extra pin for data return, which gets passed to the normal data pin of the next plug.
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Few tweaks to the setup. Got my custom cable for the Hades 68, I really like it. The Model D I've replaced with a Razer Viper Ultimate wireless.
So some changes, as usual ;)
The Kanto speakers have a new OcUK home, I wanted to move to an amp and passive speakers so I now have a Sabaj A3 amp/DAC and Q Acoustic 3010i setup, really good and they look stunning.
My watercooled PC I sold to my brother. It was a good project but ultimately overkill for what I needed. I'm finding less time to game and less enjoyment so the setup is geared more to productivity now. The monitor is an LG 4K because I spend most of the day looking at code/text/web/office.
Swapped the Razer Viper Ultimate for a Logitech G603, wanted something a little more palm and mega battery life.
I have plans for a new chair soon too.
New PC lives under the desk now.
3600x, B450 Tomahawk MAX, 16GB 3600 C16 RAM, Red Devil 5700XT, Meshify C and lots of Be Quiet! cooling.
Man of Honour
18 Oct 2002
South Coast
The pictures aren't hung straight, very unlike you :)
Oh they are, I used both a ruler and a spirit level when aligning them to the point the centre point is the exact same distance from each side wall :p
They are hung using wire behind though so naturally over time through vibrations on the dry wall will shift and move small amounts. I adjust them every few months.
13 Oct 2003
Left of the middle
That makes no difference if the wall is out
5 Mar 2009
North
You need a full length spacer to go in between the two when resetting them :)
11 Jun 2015
Bristol
I think when we move into the house I'll be going for a set up very similar to this. I'm on the fence right now about getting a 60% keyboard but as I'm working from home so much I think I'll miss the numpad, but i hate the numpad being there when gaming!
Totally copying your speakers and amplifier set up too. Can't wait til I don't have to use headphones again!
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
I wouldn't recommend a 60% keyboard, 65% is the sweet spot. Still get arrow keys, home, del, pgup/down. A numpad is good if you do a lot of work with numbers, but you can just buy a separate one if needed.
Numpad is an issue for me anytime I'm using my mouse, it's a much more neutral position for my arms.
11 Jun 2015
Bristol
Ah sorry 65% is the one I meant! It was a ducky I was looking at to replace my full size ducky.
The same happens for me if I'm playing a FPS the amount of times I hit the keyboard really winds me up!
11 Jun 2015
Bristol
That's basically the one I want but I want one in black. I have a Ducky Shine 3 (i think), had it for a long time now and it's still performing like a champ I just want something smaller.
I'd probably bring this one to my office and use it there... and annoy everyone with the click-clack noises :p
Really like some of the clean setups on here. Certainly something to aim for although I don't think I could keep it so tidy :)
That cable management though! :eek: Good job!
