What was the worst graphics card for heat?
Man of Honour
15 Jan 2006
Tosche Station
The hottest I've had was the GTX 480 but by god, that card was a beast and lasted a very long time, especially as it was a time when needing a new card every 2 years to keep up was an actual thing.
28 Sep 2013
I had a 7990, that was mental hot. Had to drill out two more fan slots in the side of the case as the side of the case was so hot to the touch.
10 Dec 2004
Oxfordshire
Think my reference Vega is the hottest i have owned, that has hit 81 under load over last few days, running undervolt and memory is at 1050mhz / fans are set to not break 2500rpm though, if I gave it a bit more slack it might run cooler tbh!. However that seems to be nothing compared to what some have suffered with on here!
19 Nov 2009
Baa
I think my 6800GT ran pretty hot until I stuck a better cooler on it (...and then flashed the vbios to give the core 1.4v like the Ultra model).
I had an X1950 Pro too which was also a hot one.
28 Aug 2017
United Kingdom
i owned a couple of gtx 295's from nvidia, the first was kept on air cooling and would readly hit 90 degrees+ whilst gaming in crysis with everything cranked to max at 1080p, then one day switched on pc and the gpu was no more, so saved up a bit and bought a second one but this time puckered up the cash for a waterblock and after a lengthly install temps were much better around 60 degrees under full load, and lasted a good few years :)
31 Jan 2012
Droitwich, UK
I had both cards and did the same to my 6800GT! A copper Zalman cooler, although I didn't flash the BIOS I managed to OC it to near Ultra speeds.
The Sapphire X1950 Pro I had was hot to the extent that I ended up taking the side of my PC's case off and pointing a desk fan at it, to help avoid issues with the Crysis demo (after later getting a 4870 I realised the card had issues, likely from day 1).
19 Nov 2009
Baa
I had both cards and did the same to my 6800GT! A copper Zotac cooler, although I didn't flash the BIOS I managed to OC it to near Ultra speeds.
Great stuff. :) I had an Arctic Cooling NV5 Silencer on my 6800GT and also ran the side of the case for both cards. I can't remeber why I didn't upgrade the cooling on the x1950 Pro (possibly no room?) but it really needed doing. That style of cooler (very similar to the stock 6800GT cooler) was hopeless.
7 Mar 2005
For me 2 x 8800GT in SLI, although I think it was the nForce 680i motherboard they were used on that actually put out the most heat. As soon as Crysis had been completed it was all replaced, as gaming in shorts in December did not bode well for the coming spring/summer.
6 May 2011
Milton Keynes
Probably not the highest TDP of some of the cards on here, but I had a reference R9 290 that would run just north of 90c, wasn't the best card I've owned, either it ran warm of sounded like a jet engine if you turned the fan up. Never bought a reference blower again after that.
