First ever attempt at water cooling, up until now every PC I've had has been air cooled. Skipped AIO and went straight to custom loop. It's been a long time coming because I've had problems with my back, but finally got it together this evening:
Need to get the RGB LEDs inserted into the CPU waterblock and connected up, fancy a small RGB strip down the left inside of the case to give some extra lighting. When I come to get my GPU waterblocked, then I'll change the tubing layout. I was kinda hoping that the vertical bit of soft tubing might stay straighter, but it doesn't want to!
Quite pleased for my first ever attempt, please be gentle
Edit on 21/10/20:
And this is what the system looks like now, after I waterblocked the GPU several weeks ago. Cabling since tidied up and paper towels removed
