So I wanted clarification on the whole Gamepass Ultimate (GPU) issue if you were to buy an S/X via All Access.
I found out via live chat that the All Access 24 months GPU will be baked into the console. So you’ll get an option to activate it there and then on the console when you’re setting up or later (which is done in settings). So if you have GPU until 2023 for example, you can let that sub go down, then activate the 2 years All Access whenever you want.
But I went further....
I wanted to know about the situation regarding buying outright so called Microsoft. Seems a bit unfair that people buying via All Access get GPU for 2 years and not those buying outright.. Now I can’t say whether this person had the right info or not but he seemed very confident that there was going to be a code of some kind (in the box of the S/X, emailed to you or on a receipt) saying that for £/$24.99, you get 2 years worth of GPU....
I literally got him to confirm this 3 times to make sure I had it right (only a technical support dude after all... ) Because for me, £449 + £24.99 (for 2 years of GPU) = £473.99 is a substantial saving. But he seemed adamant that this was a thing and would be announced soon (when pre orders go live perhaps?).
Just thought I’d share what I found out. I’ll believe the outright info when I see it but the All Access stuff is a lock.
