- 28 Sep 2014
Update:
Opened my GPU, pushed the pins back into the power connector, plugged in the 8-pin cables, made sure to push the pins all the way in from underneath the card's power connector, put on some new thermal paste, put the whole thing together and now it's running like a dream. It was a very easy fix, but I've never done it before so i was a bit sceptical. Glad i did it though. I must say I am astounded how they we're able to ship this card with this power connector though. I'll probably have to go through the same process again if i ever plug the power out of the card.
I agree it is an easy fix but if you have not done it before it might be a bit scary. Also, it is not something you should trouble yourself with when buying a brand new product.
