As usual, the Tamiya car kit is amazing as is the very detailed Meng Typhoon.
I right in saying it just bleeps your phone when the pressures drop offfor £230 a wheel
I bought an MRI scan to find out my back was a write off!
Ruptured disc, seeing a consultant next week, looking like I may need spinal surgery, fun and games
ouch... I had a very similar rupture.. 5 years of pain before I got it sorted properly..
I was offered keyhole or open surgery, obviously key hole is cheaper but the consultant said open is better since he can get a good look and make sure it’s well and truly sorted.. I went for that and so glad I did, whilst most of the damaged nerves never repaired, I have no pain and no repeat issues.. Friends who went for keyhole due to cost have been back twice and still not quite sorted.
A few more brewing components showed up. 15 gallon kettle, recirculating pump and fittings and connectors.
Also got a Blink Mini on Prime day, which I have set up as FermentCam for now to check it doesn't explode.
No, you are not right. It monitors my pressures for £100 for both wheels.
Good to know about the different surgeries thanks!Believe the consultant i'm seeing is a specialist in keyhole so will see how Tuesday goes. Also believe he likes to avoid surgery at all costs, so will see.
How was the recovery from the open surgery out of interest? How long were you out of action?
<snip>
I was quite fortunate, the surgeon/consultant I used also did some quite prominent Rugby players and from my MRI it was quite a bad prolapse which prompted the switch from Keyhole to open surgery.
In terms of recovery, pretty much within a day I was up and about, however I did require 4 weeks off work..
As a procedure it was hilarious, I've not had any major op's prior to that so had no idea what to expect (other than pain), however, when I as anaesthetised all I remember was starting a count, then a really nice/deep sleep, when I woke up I was still on my back and felt absolutely zero pain (the best sleep I've ever had!), I actually asked the nurse what had gone wrong (assuming they wouldn't have laid me on a fresh wound, and with zero pain or sensation, I assumed the surgery had been aborted).. She said, oh no, it all went really well and I'm now in recovery.. I was genuinely surprised!
I was in hospital for 1 night and left the following day, they gave me a morphine line to self administer, which was great! but I didn't really need it, just a tiny bit of soreness with the wound knitting, but honestly pretty much nothing compared to my previous back pain!
For reference, my Mrs had her gall bladder removed via keyhole last year, she had 4 weeks off work to recover and if anything had more pain/issues due to bruising/scarring of tissue/muscle around the keyhole sites (5 in her case). Obviously open surgery carries a slightly greater risk of infection and is slightly more expensive but carries the benefit of being able to visually ensure they've opened things up as much as possible, this isn't easily done with keyhole.. but that is only if you have a severe prolapse as I did.
I had got to the point I lost 70% of the strength in my left foot (could not stand on my toes on that foot), this has not recovered due to the severity of the prolapse.
I had a prolapsed disk as well. Had it shaved somehow - microdiscectomy I think - and it was incredible. I was up and walking on the same day with no pain. I know avoiding surgery is often the best option, and I'd recommend you strengthen your back (not a doctor, but it helped me), but the surgery really was incredible. It gave me instant relief.
Feel free to message me if you've any questions.
That does look like a nice garage to be.
Overall cost all in?
Is there room for storage in what would be a loft, or are you just having it all open space?
£25k lols someone got bent over I'd expect a brick build for that.
https://www.tuin.co.uk/Garages-And-Carports.html
