2 Nov 2020 at 08:49 #1 polshy polshy Associate Joined 4 Apr 2017 Posts 11 Hello folks, Any one have any advice on what size I'd need for the system above? Will have a single d5 pump running with 7 case fans. 4 for the rad and then 3 for case air flow. Appreciate the help in advance. Cheers!
2 Nov 2020 at 09:27 #2 mickyflinn mickyflinn Man of Honour Joined 23 Mar 2011 Posts 18,989 Location West Side 750 to 850w is enough but grab 1000w if you can get it at a good price.
2 Nov 2020 at 09:47 #3 polshy polshy Associate OP Joined 4 Apr 2017 Posts 11 Do you think super flower 850w gold is decent for 125? Not really sure If I should hold out and see if there are any November deals as its already at 10% off. Cheers for the help!
2 Nov 2020 at 10:09 #4 mickyflinn mickyflinn Man of Honour Joined 23 Mar 2011 Posts 18,989 Location West Side polshy said: Do you think super flower 850w gold is decent for 125? Not really sure If I should hold out and see if there are any November deals as its already at 10% off. Cheers for the help! Click to expand... Is that the rgb version ? Yes they are quality units with a 7 year warranty but most other manufacturers offer 10 years. Not much choice on psu at the momment
2 Nov 2020 at 10:24 #5 polshy polshy Associate OP Joined 4 Apr 2017 Posts 11 Yes its the RGB version which I'm referring too. it seems to be reasonably priced and its at its lowest in terms of history.
