Do you have start stop system turned off?
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
I bought a 2017 Ford B-Max Zetec Navigator 1L petrol back in September which has it and I was dubious about it at first but gave it a chance to see how it worked. It only shuts the engine down if I come to a stop, apply the handbrake and take the car out of gear and even then only if the the heater/air con isn't set to maximum. I think it's only happened twice so far so have left it on. Engine restart is instantaneous on dipping the clutch to engage gear so there is nothing to lose by leaving it on.
1 Mar 2010
Yes, that's the other point additional stress on the more expensive AGM battery - are these batteries typically lasting as long as their conventional prdedecessors ?
(but they're covered under the warranty of course),
plus, a beefed up starter&mechanism, another failure point ... all for a few grams of CO2 dollars more
18 Oct 2002
As annoying as the system is I just leave it switched on.
My 2019 Q7 does this as well. The engine stops and as the car in front pulls away, the engine restarts.
From my experience, the car in front pulls away 5 inches then stops, repeat times x. So in a traffic queue the engine might stop & start many times and each time you only move forward a very short distance. The engine might as well just stay on.
20 May 2007
Used to leave it on in my last two cars (A5s) but the first thing I do after starting up my CLS or the Mrs' A Class is turn it off. Horrid thing
May be a Merc thing - i hate their SatNav too, but that's another thread
16 Aug 2004
New Jersey, USA
The BMW with (gps) adaption on the automatic gearbox, so, why not an adaptive stop/start system that recognises roundabouts ?
do they use stop-start in the USA where, obviously, they have to stop at junctions ? I assume not
Yes...? Also contrary to popular belief roundabouts do exist in the USA, they just prefer to use all way stops for some reason.
I have no issue with start/stop systems, having the engine turned off when sat still makes perfect sense to me.
Thats "City braking" lol.
Someone loaned me a Yaris which had that. It went off within 10 minutes after it kept going mental between parked cars and oncoming traffic. It's just asking to be rear ended.
I have two cars with AEB and neither have ever done that, sounds like more Nasher nonsense.
18 Oct 2002
Yeah, it's intelligent enough to stop activating in these situations.
9 Apr 2007
Leave it on all the time, saves fuel.
Much prefer the Mazda system though, such a good idea, shame everyone else doesn't do it the same way.
Man of Honour
26 Dec 2003
Shropshire
Mine doesn't kick in again unless you've gone over 10mph(?) since it last activated so unless you're living your life quarter mile at a time when the car in front moves you're safe.
Man of Honour
17 Oct 2002
Iirc he last had a 5 series which does exactly that so not sure what he is on about.
Man of Honour
29 Jun 2003
Wiltshire
No issues with it on my Golf, if I see the trafic ahead is about to move just before I stop I just hold the clutch in for a second. I find the AC/CC stays cools for a minute or so after and if its idle that long with engine off (2-3 mins) it comes back on which I think it due to the cooling needed in the cabin to match the CC temp setting.
I think the 2 cylinder mode is the best feature related to saving fuel though on mine :)
Man of Honour
19 Oct 2002
Surrey
Auto stop/start is only there to help the manufacturers pass emissions tests. It's not there to actually reduce emissions in real world situations and certainly not there to help the average person. Indeed it is likely to cause more wear long term on the engine, resulting in more maintenance.
Man of Honour
17 Oct 2002
It makes sitting at the lights a wonderfully silent affair.
19 Oct 2002
Shakespeare’s County
Well it reduces CO2 output on the test, which means less fuel use. Quite simple.
18 Oct 2004
Kent
On the test.
Are you saying that reducing the amount of fuel used in a test scenario is not applicable to real world driving?
If so, could you expand on why? I could understand if you were talking about efficiency testing, because there's so many variables to consider and/or manipulate to determine efficiency whilst on the move, so there's elements of that testing which might not apply in Real Life (TM).
But we're talking about when the car is at a standstill. Surely there is no way that turning the engine off during this time can do anything other than reduce fuel usage, whether for a test or for the end user (obviously accounting for idling time fuel use vs fuel use starting the engine).
Man of Honour
19 Oct 2002
Surrey
Are you suggesting that having the engine off uses more fuel?
Not at all. I'm suggesting that in the real world there might be increased fuel consumption due to the constant engine restarting. The test also doesn't look at what happens a few years later when the engine is older and worn. Where are the long term studies over the lifetime of the vehicle on emissions of fuel and (possible) additional maintenance?
We shouldn't just assume that because a car was tested in a relatively controlled way before it is sold, that it represents the real world over 10 or 15 years.
Happy to be corrected of there are some reliable lifetime studies which have been done.
