- 4 Sep 2009
Hi guys, I'm putting together a mini build for a friend.. he needs it for light home studio use - all inside the box, no outboard gear other than a USB interface. He just needs something reliable and with enough processing power to handle Reaper and Cubase with a reasonable amount of plugins etc. He doesn't want to spend much more than I have put together in this basket - but I'm a bit out of touch with the current tech, so I'm looking for your expert advice as to whether the components I've selected will work well together or, if there are better alternatives for roughly the same cost. Thanks for taking a look.
My basket at Overclockers UK:
- 1 x Intel Core i5-10400F 2.90GHz (Comet Lake) Socket LGA1200 Processor - Retail= £139.99
- 1 x Asrock H410M-ITX/AC (Socket LGA 1200) DDR4 Mini-ITX Motherboard= £93.95
- 1 x Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey= £59.99
- 1 x WD Blue 3D NAND 500GB M.2 2280 Solid State Drive (WDS500G2B0B)= £56.99
- 1 x Kolink Enclave 500W 80 Plus Gold Modular Power Supply= £47.99
- 1 x Silverstone Sugo SG13B Mini-ITX Chassis - Black= £39.95
Total: £450.56 (includes shipping: £11.70)
